Question about SanDisk Sansa e250 MP3 Player
Clock doesn't keep time anymore
It's just a minor annoyance, but the clock on my sansa stopped keeping time. It still says 1:12 pm, 5 hours after setting it at 1:00 pm, and when i listen to music it doesn't move at all. How can i fix this problem?
Go into settings an reset dafault
Posted on Jan 04, 2008
My neighbor age 93 is having trouble turning back her alarm clock; can you give me the directions.
Depends the make and settings but to set mine I push the time button keeping it pushed with one hand then push the hour button with the other and that should make the hour numbers go. You have to do this till the time goes to where you want.Say it is now 3pm then go around to 2 pm. That sets it back one hour. It will take you to the am and keep going to the pm.
Nov 06, 2016 | Audio Players & Recorders
How do you change the time from a 24hr clock to a 12hr clock. For example clock says 19:50 instead of 7:50 pm on a Brookstone 5-in-1 Sensor Clock.
Selecting 12- or 24- Hour Mode While in the Time screen, press or to select either 12- or 24-hour mode. If 12-hour mode is selected, PM displays for the afternoon/evening hours. AM does not display for the morning hours http://origin-www.brookstone.com/webassets/pdf/740687p_manual.pdf
Apr 06, 2016 | Brookstone Audio Players & Recorders
How do you set the time? I figured out the alarm clock but can't find a way to set up the time.
Setting the Clock
1. Press and hold the HOUR button for 5 seconds (Fig. 5). The time will begin to flash
2. While the time is flashing, press the HOUR button until you reach the correct hour. Then press the
MINUTE button (Fig. 5) until you reach the correct minute.
NOTE: PM indicator will appear on the left side of the clock face for evening hours (Fig. 5). If the
PM indicator is not illuminated, the hour is set to AM. Be sure to set the time for the correct
12-hour period - AM (morning) or PM (evening).
NOTE: After 5 seconds, the time will stop flashing and it will be set.
Mar 03, 2011 | Homedics SS-4000 Clock Radio
Somehow the clock is displaying 24 hour time format. I want to get back to 12 hour format. How?
Push the mode button twice to enter the "set time" mode. Once the digital display is blinking, keep pushing "mode" until the PM display section in the upper left corner comes on. Once that happens you are back to the 12 hour clock. To set the clock, use the 1-4 buttons to set the hours and minutes.
Hope this helps.
May 11, 2010 | Sharper Image SI686 Clock Radio
HOW DO I SET THE TIME ON THIS CLOCK? I FOUND HOW TO MOVE THE MINUTES, BUT CAN'T FIGURE OUT HOW TO MOVE THE HOUE.
Casocojo67,
It is a slow process, but by holding down the minute buttons, cycle past the 60 minutes and the hour will also change. Then you will need to be sure you have the AM/PM set if you want to use the alarm for the proper time.
I found our manual last night, and it is very annoying to have to spend so much time on such a minor issue. I blame designers.
good luck
Jeff
Sep 29, 2009 | Zenith Z228T Clock Radio
Set time on Touch Screen Thermo Clock
Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
1. To set the time, touch the clock icon on the upper left corner;
2. Keep touching the screen for longer than 5 seconds, on the hour area;
3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
4. Touch the clock icon again to start the clock;
5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
6. To set the date, tocuh the calendar icon on the left hand side;
7. Keep touching the screen for longer than 5 seconds, on the year area;
8. Touch the year area until you get what you want;
9. Touch the month area until you get what you want;
10. Touch the day area until you get what you want;
11. The screen will reverse to the time display after 5 seconds if no touch.
12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
Hope it helped.
May 08, 2009 | Watches
1985.5 PORSCHE 944 digital clock (changing time)
There are three buttons, let's call them 1, 2, and 3, from left to right.
Clock
Time setting
A. 12 AM, PM or 24.00 h
With the clock in the time readout mode, keep
button (2) depressed for 4 seconds -12 AM, PM
or 24.00 flashing. After pushing button (1), either
a 12-hour (AM + PM) or a 24-hour setting
program can be selected. If you only want to
change the display mode, push button (3). The
clock then returns to its normal timekeeping
function.
B. Hours
Push button (2) a second time - hour display
flashes. Set hour by pushing button (1). After
pushing button (3)*, the clock returns to the time
readout mode with new hour setting.
C. Minutes
Push button (2) once more - minute display
flashes. Set minute by pushing button (1). Upon
pushing button (3)*, the clock is started -
accurate to within 1 second.
Stop watch function
The stop watch can only be set in motion if the
clock is in its normal timekeeping mode and not
during setting operations.
A. Push button (3) - 00:00 display appears;
B. Push button (1) - stop watch is on;
C. Push button (1) a second time - watch stops.
(Additional times can be added by pushing button
(1) again - stop watch keeps running. Push button
(1) once more to stop timing.)
D. Push button (2) - 00:00 display appears;
E. Push button (3) - normal timekeeping mode.
If button (3) is pushed during operation A and
B, the setting procedure must be restarted
Apr 17, 2009 | 1985 Porsche 944
12 hour vs 24 hour read on clock
Push the "mode" button twice to enter the time change function. Once the display is blinking keep pushing the mode button until you see the "pm" icon on the LCD display. When that happens set the clock as you normally would using the 1-4 keys.
Remember to check if the 12 hour clock is set to AM or PM.
Good luck.
Sep 09, 2008 | Sharper Image SI686 Clock Radio
Savings time
This is more of a Clarification than a solution.
I've determined that the SS-5000 is not recognizing the changes to DST that happened in 2007.
From 1986 to 2006 this was the first Sunday in April to the last Sunday in October, but starting in 2007, it is observed from the second Sunday in March to the first Sunday in November, adding about a month to daylight saving time.
So in March the clock is still trying to keep the "earler" time and in November it's trying to keep the 'later' time.
I'm contacting HomeMedics Support to see if there's a resolution.
Mar 17, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
SanDisk Sansa e250 MP3 Player Logo
78 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
