To raise and lower the cooktop:
1. Remove all items from cooktop and set aside.
2. Grasp the sides of the cooktop and then lift from the
3. Lift the cookop high enough to allow the support rods
to snap into place. The llft-up rods will support the
cooktop in the raised position.
4. If necessary, clean underneath using hot, soapy water
and a clean cloth; then dry.
5. To lower the cooktop, grasp the front corner of each
side of the top while pushing back on each rod with
the heel of your hand. This will release the notched
support. Hold the range cooktop and gently slide the
top back down level to the range.
Thank you for your post, isaak goldman!
I understand that you are seeking instructions in order to replace the cooktop on your Frigidaire range. However, this is not a simple DIY job. I would recommend having a professional technician come out to ensure that the range is properly disassembled and the cooktop installed correctly to prevent any future issues. Hope this information is helpful. -Matt
