Nintendo DS Lite Console Logo
Anonymous Posted on Jan 04, 2008
S lite left and right hinge issues....the source is actually the right side??
SO I get a replacement shell from ebay and go to work on replacing the classic left hinge and my sons right hinge (has the top section broken off)as well. After 3 hours and nearly getting back together I realize this metal part of the hinge on the right that you insert into the replacement housing and then fit into the lighted replacement tab just doesn't rotate.. You see this is the actual hinge of the top DS screen section .....the left just freely turns since the screen connections and such are there. This lack of rotation is actually the source of the NDSL hinge problems because of the torque/force put there...... So long story short have I been staring at this thing too long.... can I get a replacement hinge insert there....or is this not supposed to work right and we all suffer hinge problems?? Please HELP
  • 1 more comment
  • Anonymous Feb 06, 2008
    I'm just about to purchase a replacement housing for my son's NDSL, due to a broken right hinge. Were you able to resolve this problem, and if so, would you be kind enough to share which replacement kit you purchased? Thanks!
  • JollyBuda Apr 14, 2008
    My right hinge part has completely come off! As in the bit of plastic near the R button which housed those clear strips that showed the power light is know gone and has only the bare light.....My warranty is out too! I don't know what to do!!
  • Julie74 Jan 09, 2009
    Hi, I done the same thing. I waited patiently for my ds lite housing and top screen to arrive from deal extreme, then screwdrivers were on back order. Finally received everything I needed, spent hours on replacing the broken bits then got it back together and realised I have also lost the metal hinge from the right side. Searched ebay for "METAL HINGE DS LITE" I had only 2 to choose from. Arrived today and now I am trying to figure out exactly how it is meant to sit. I will let you know how I go. Hope this gives you some hope.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 13, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
700
Points
Get this:
http://www.dealextreme.com/details.dx/sku.15853
Replaces hinges on both left and right.
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jan 12, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
1215
Points
Try buying more eggs next time 4 french toast
If the hinge has a crack will that cause a problem, and if so where can you buy just the shell?
If there is a slight crack this will not cause a problem as long as the hinge isn't loose and the screen isn't moving.
The cheapest place to buy a replacement shell is on ebay. However this would void any warrenty you have.
tip
DS Lite Dismantling Process, Ideal For Shell/ Housing/ Casing Replacement.
Has you DS lite devloped an issue that requires you to take it apart? Has your shell/ housing/ casing becomed damaged or is scratched? Have you broken the hinge and want to replace the relevant parts? This guide is for you.
N.B. - It is lengthly but thats because it is an indepth guide to make it suitable for even the most novice of people.
For this process you will need a few tools (all avaliable on ebay):
1) A precision cross-head "+" screwdriver.
2) A precision tri-wing screwdriver.
3) A pair of tweezers.
4) A craft knife or scalpel.
5) A flat-head "-" screwdriver or cutlery/ butter knife.
To begin you need to remove the battery, unscrew the battery compartment with the cross-head screwdriver and then lever it off with the knife. Next remove the battery by levering it out, you will see a small lip on the right hand side near the top, lever it up there. Now you need to remove the remaining 3 cross-head screws, their locations are:
1) Top right of the battery compartment.
2) Under the rubber foot next to the left shoulder button, lever the rubber foot off with the knife.
3) Under the rubber foot next to the right shoulder button, again lever the rubber foot off with the knife.
Screws 2 & 3 are of a gold colour whereas screw 1 is silver in colour.
Note there is another cross-head screw that is visible in the battery compartment, we will leave this one for now.
Next you need to remove the 4 tri-wing screws, these are located:
1) Top left of the base of the DS lite, just under the right shoulder button.
2) Bottom left of the DS lite, below the stylus slot.
3) Bottom right of the DS lite, its tucked right in the corner of the battery compartment.
4) This one is a little harder to see and a lot of people miss it... It's located at the top of the slot -1 port as you can see it is black and shorter than the others.
Now you can remove the back, gently pull it away from the top first and then lever it off at the bottom taking care not to lose the springs and rods found on the shoulder buttons. Take off the shoulder buttons and take a good look at how the springs are positioned as this is crutial to the performance of the button, take a photo of them if you have to.
To remove the motherboard you'll need to disconnect the wi-fi cable (black in colour) located on the wi-fi module (the extra piece of PCB* board attached to the motherboard) use tweezers to do so and then remove it from under the slot -1 component. Again using the tweezers, disconnect the microphone cable (white in colour) which is located on the motherboard directly diagonal to the top left corner of the wi-fi board, labled "p12".
Now remove the 2 screws holding the motherboard into place, they are located:
1) On the left hand side about 1inch above the headphone socket.
2) On the right hand side about 3/4inch above the volume switch.
Flip the motherboard up and over taking care not to put any strain on the top and bottom screen ribbons.
Disconnect the top screen by lifting the securing flap (if you have trouble use the knifes blunt side to lift it) and pull the ribbon away. Remember to put the flap back down after to avoid breaking it. This will now fully free the motherboard from the DS lite shell. If you need to, disconnect the bottom screen by again lifting the flap of the connector and pulling the ribbon free and then remove the touch screens ribbon using the same method, It's connection is located just above the wi-fi board. Remember to put the flap back down after to avoid breaking it.
If you need to replace the buttons or pads you can do so now, you will also see that you cannot put the buttons back in the wrong place because they are unique to their respective places. When replacing the pads make sure that the "black dots" are visable i.e. face up.
You will see 2 cross-head screws located at the top left of unit, if you unscrew them you can pull away the hinge which in-turn losens up the other hinge, but before you part the top from the bottom slip the top screens ribbon through the slot to release it and feed through the wi-fi and microphone cable. Now you can seperate the top from the bottom and if you need to, replace the hinge barrel and ring by pulling them away from the body of the DS lite and fitting the new ones in the reverse of the removal.
Now for the top half of the DS lite...
Firstly you need to remove the 4 cross-head screws, they are hidden under square, colour co-ordinated plugs and are located near each corner of the inside top half of the DS lite. To remove the plugs use the knife to lever them out but take great care as they are easily marked/damaged. Once the screws are removed you need to turn the unit over so that you can see the DS symbol and have the hinge side nearest to you. Place your thumbs on the top and your fingers on the bottom, now push away from you with your thumbs so that the top slides forward around 1/5th of an inch, you can now take the top off to reveal the insides.
Take note of how all the items are placed or take a photo if you need to. Firstly you can feed the top screen ribbon, wi-fi cable and mic cable through the hinge hole. The speakers are not stuck down and are held into place by the plastic housing so are easily lifted/ levered up. The wi-fi PCB* board is secured in much the same way and so removal is identical.
You need to loosen the screen in order to remove the microphone cable as it is held under the bottom of the screen, you will need to use a moderate amount of force to unstick the screen from the housing, use a flat-head screwdriver or cutlery/ butter knife to lever the screen out and away from the housing pull the microphone out of the housing either with tweezers or gently pulling on its cable.
Congratulations!!! you have now fully disassembled your DS lite! Give yourself a pat on the back.
To re-assemble the DS lite simply reverse the process. Tip- when putting the springs back make sure you put the end back into the slot so that it is taught and the shoulder button returns to its resting position after being pressed.
*PCB - Printed Circit Board
I hope that my guide has helped.
I take no responsability for any damage that may occur whislt following my guide, tips and tricks.
Regards,
SOD69
on Feb 08, 2010 • Nintendo DS Lite
Nintendo ds lite
It's not easy at all. My company does repairs on PSP, XBox 360, PS3, Wii, and PS2. But we don't touch DS Lites. The following company will do it for you at a reasonable cost:
http://www.consoledude.com
They do all of our DS Lite repairs!
Also make sure you get an OFFICIAL Nintendo shell case. Some of the aftermarket ones don't fit properly. The following website sells the shells:
http://store.richspsxparts.com/newcoornidsl.html
Nintendo top pulled off hinges
Look on ebay for replacement shells for DS.
There around $15 and you also need to buy a Special Nintendo Screwdriver
1helpful
Nintendo DS Lite Broken Right Hinge & failure to stay powered on
the nintendo DS IS A *******!!!!!!!!!!!!!!!!! PIECE OF **** YOU ******* ****
Ds lite
yes the new shell has this piece it's just not in the photo, it's in a bag not seen in most photos, you can replace this for about $25.00, or use a repair service on ebay
3answers
Cracked hinge and chipped corner on DS LITE
yes the shell can be replaced, you can either check ebay or google nintendo ds lite shell housing, i have seen them, doing this yourself is no easy task, there is a repair service on ebay under repair service fix nintendo ds lite
2answers
Broken Hinges
i suggest you buy a replacement shell from ebay and check out the u tube video on disassembling
2answers
Broken Hengis
if you havn't had it for a year,, you might be able to take it back where u got it and get a new one,
DS broken in half
I recommend you to change the broken case, you can choose to change only the hinge and keep the good case parts or change the entire shell. By the way stores usually sell the entire shell so you can choose. As your screens are still working you are lucky because so often the brown flexible conductor to the top screen get broken so be careful.
You can also use a silicon or hard plastic case to put over your broken NDSL to keep it in place just as the fast non technical option.
Here are some links and you can find text and video guides googling around.
Shells in ebay
Other stores items
Good Luck...
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
