Question about Sony Ericsson P990i Cellular Phone
Wheel Spins free
Hi. The wheel on the left side of my phone spins free. Is it something I can take apart and fix? How do I take it apart? edctalk@yahoo.com
If you solve my problem then only I am eligible to solve others problems.
Posted on Jan 04, 2008
Wheel spins freely in park
Is the tranny actually in Park? Make sure the shift adjustment is correct. If should start only in park or neutral in any other position shift adjustment is incorrect.
Mar 23, 2015 | 2003 Kia Sedona
Grinding/whining noise from gearbox/final drive - fiat 500C Lounge - 2010 model
I think removes the tyre both then check its gear box bearing noise or clutch plate bearing noise
Dec 16, 2013 | Cars & Trucks
2005 Honda XR 125 L speedometer cable spins backward
Hi, Chris you have the speedometer drive unit on the wrong side of the front wheel for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere $15 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
NEW HONDA XR125 XR 125 SPEEDO CABLE ALL YEARS eBay
Honda XR 125 Broken Speedometer Fix
Xr125l Bike 2003 2011 Workshop Service Repair Manual Download Manuals... $15
https://www.partsfish.com/page/oem-parts-for-honda
Honda XR125LK Owner Manual
Feb 21, 2018 | 2005 Honda XR 125 L
Ge electric harmony dryer fan motor not turning just moves side to side 1/4 of an inch back and forth . fan freeweels free, if i spin it buy hand.
with belt off see if motor free spins .the blower wheel should not free spin with the belt on and entire drum will turn with it otherwise you could have a bad motor and a blower wheel
Jan 24, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
It seams that only one wheel spins. When i have one side of the truck on ice and the other side on dry pavement, the wheel on the ice spins and the truck do not move. the wheel on the dry pavement should...
unless you have a limited slip differential(which means both wheels have power from the engine to them at the same time),only one wheel will spin, and it will be the wheel that can spin the easiest.throw some sand or salt on the ice to give that wheel some traction,and you're off
Jan 17, 2010 | 2007 Mazda B3000
Hi i have a problem with my back left wheel. When
Could be pads, or your parking brake is set on that side. Calipers mite be bad.
Dec 12, 2009 | 2000 Toyota 4Runner
I don't know how to change the grinding blade on my makita angle grinder.
There is a nut that you release from the middle of the grinder wheel, (grinder blade)
This nut is flat and has four holes in it.
You will see you are providing a spanner wrench to remove this nut. The wrenches' actual name is Lock Nut Wrench. It has a U shaped end with two pins sticking out. On on each side of the U shape.
The pins are inserted into the holes in the flat lock nut, located in the middle of the grinding wheel. The wrench is laid flat against the grinding wheel, with the two pins of the wrench going into any two holes of the nut.
At the top of the Makita grinder you will see a Black button. The button is pushed down to keep the grinding wheel from spinning. Holds the grinding wheel in place, as you turn the lock nut loose. When you release the button, a spring inside pushes the button back up out of the way.
As you view the Makita grinder, Release Button towards the Back, grinding wheel towards you, the nut is turned to the LEFT, to loosen. It is a Left threaded nut.
The grinding wheel spins to the Right. Using a left threaded nut insures that the nut will stay tight, due to the direction the grinding wheel spins.
Oct 01, 2009 | Makita Usa Inc 9557PB 4 1/2" Angle Grinder
Wheel wont spin any more...i took it off to fix a flat tire and when i did it was all cool until i put it back and the wheel wont spin any more...why?
it sounds like a spacer or washer is missing causing the bolts to tighten to much on the wheels hub, try to loosen the bolts a little if the wheel spins you know thats the problem and something is missing.
Mar 20, 2009 | Cycling
Sony Ericsson P990i Cellular Phone Logo
26 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
