Question about Epson LX-300 Matrix Printer
EPSON LX-300 I have EPSON LX-300. And acing HEAD JAMproblem when on the printer.
    Problem Solver:
  • 7 Answers
Carrige unit cheng
Posted on Jan 29, 2008
    Problem Solver:
  • 16 Answers
Check the flex cable / cable wire attached on cartridge maybe thier a short on the cable.. also check the selection switch..
Posted on Jan 04, 2008
How many pins available in the epson lx-300+II printer head
There are 9 pin heads. Here is a link to more detailed info and specs about the printer http://files.support.epson.com/pdf/lx3pii/lx3piipg.pdf I hope i understood your question. Take care
-Rp-
Mar 08, 2011 | Epson LX-300+II Matrix Printer
Epson lx 300 + # print not readable
if the print out is not readable.. most probably your print head pin is broken.. you can check your print head by removing it.. just unscrew the screw holding the print head and look at the front portion of the print head..over there are rows of pin.. see if the pin is even else it's broken..
May 21, 2010 | HP Color LaserJet 2600n Printer
IM HAVING DIFFICULTY REMOVING THE INK CARTRIDGE FROM MY EPSON LX-300+II, THE RIBBON MUST BE JAMMED ON TO THE PRINT HEAD
first pls remove the power cable after >Open the top plastic lid. > Slide the printer head to the middle of the printer. > Pull the printer cartridge up and out evenly.
Feb 22, 2010 | Epson LX-300 Matrix Printer
My printer epson dot matrics lx 300 + writes first 2 lines correctly but next lines in italic. what is the solution?
DEAR,
PL CHECK YOUR PRINTER HEAD IS STUCKING OR NOT.
1ST FILL OIL IN PRINTER ROAD (HEAD MOVES ON)
2ND CHECK YOUR PRINTER HEAD BLOCK BUSH IS PROPER SITTING OR NOT.
Feb 26, 2009 | Epson LX-300 Matrix Printer
No power on epson lx300
no power in printer give solution how to repair this
Jan 19, 2009 | Epson LX-300 Matrix Printer
Epson LX-300+II, the font problem
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
Sep 06, 2008 | Epson LX-300+ II Matrix Printer
have you check the white cable? (from the printer head to the
mainboard) .If the white cable is ok and you confirm that the
printer head is fine, then the problem is at the mainboard.
most problems like this that i had encountered is at the transistor
at the mainboard. Try to check it out using a multitester.
NON STOP OF HEAD
Turn the printer off. Hold down the load/eject,LL/FF, and Pause buttons while you turn the printer on. This will restore the default setting for your printer.
Jan 29, 2008 | Epson LX-300 Matrix Printer
Epson printer troubleshooting
hi there, you do have a ribbon cable problem, the white strip wire which is connected to the head of the printer. repalce the ribbon head cable and add some cleaning and lubrication on your printer machine. ty
Dec 23, 2007 | Epson LX-300 Matrix Printer
Epson LX-300+ Matrix Printer Problem
Please change the setting print direction from bidirection to unidirection.
Nov 05, 2007 | Epson LX-300 Matrix Printer
Epson LX-300 Matrix Printer Logo
299 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
