Home | LG | LHD45EL Dehumidifier | The top condenser coi...
LG LHD45EL Dehumidifier
Problem for LG LHD45EL Dehumidifier
The top condenser coil gets
By promos on Nov 03, 2009
The top condenser coil gets frost on it and is really cool, but the other coils do not get cooled at all. For this reason, the unit doesn't produce even 10% of the normal water in the catch bucket. Outside air temp is about 82 degrees F, so that should not be the problem. I have an identical unit and it works great with all the condenser coils getting cool. I'm wondering why the cooling fluid can't make it past the first coil. thx
Solution #1
posted on Nov 03, 2009
Not Rated)
nanbuenbrazo
Rank: Wiz
Rating: 78%, 155 votes
The way i see it, there 's a two possible reason why this happen
1. maybe you have a leak and your refigerant is under charge, why do'nt you open up the unit and do some leak testing by using soap bubble.
2. it may be clogged, How old is your unit, it is just a hint but maybe when your system reach a certain degree or level of temperature reading, even though your motor is running but the refrigerant can't pass thru the capillary tube(the very thin copper tube) and clogged onthe strainer. But this is too technical so I advise is you might need some actual technical assistance from a tech guy.
Was this helpful?
Yes
No
Popular Solutions for LG LHD45EL Dehumidifier
Questions and Unsolved Problems for LG LHD45EL Dehumidifier
Do you recommend LG LHD45EL Dehumidifier?
Answer
Answer
i have 4 ea new lhd659ebk dehumidifier and they make lots of noise and vibrate a bit, this is normal... (More)
Answer
the bucket full light is on and unit will not run. Unit has hose adapter in use.
Answer
The dehumidifier powers on and immediately stops with display error code Ch 01 Bucket is empty,... (More)
Answer
the machine sounds like it's running fine. it turns on and off on its own, but the bucket is not... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For LG LHD45EL Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
