Home | Hobart | AM14-253 Free-standing Dishwasher | AM-14 'Hot Motor' l.e...
Hobart AM14-253 Free-standing Dishwasher
Problem for Hobart AM14-253 Free-standing Dishwasher
AM-14 'Hot Motor' l.e.d staying lit.
By Binderman on Nov 03, 2009
AM-14 'Hot Motor" l.e.d is on causing the washer to not operate except in manual mode. The l.e.d is on as soon as the washer is turned on, so I feel its not a actual heat issue. I am replacing the pump motor for other reasons and am hoping this solves the "hot motor" issue also. Two guestions, how does the washer monitor the heat of the pump motor and is there anything else that could cause this l.e.d to stay lit besides a truely hot motor?? Thanks for any info in advance!!!
Solution #1
posted on Nov 08, 2009
Not Rated)
traboH
Rank: Master
Rating: 94%, 8 votes
1. The motor has thermistors( http://en.wikipedia.org/wiki/Thermistor ) installed internally. They are monitored by the control board to protect the motor from overheating and burning itself out should a fork or some other object find it's way into the pump and jam it.
2. More than likely, the thermistors have gone bad. I've yet to see the hot motor led light for any other reason.
The board can be "tricked" into thinking the motor is cool at all times but it requires bypassing the overheat protection circuit. Replacing the motor like you stated, is the proper thing to do. I'd be really surprised if after replacement your light didn't go out. All the best.
Was this helpful?
Yes
No
Popular Solutions for Hobart AM14-253 Free-standing
Questions and Unsolved Problems for Hobart AM14-253 Free-standing
Do you recommend Hobart AM14-253 Free-standing Dishwasher?
Answer
Answer
Hi, My dish washer water doesn't get hot anymore. I;ve stripped the heating element and put a... (More)
Answer
Low Heat on booster unit Psi gauge not in green zone
Answer
No heat on booster unit low temp Operating temp only 70c
Answer
What soap is recommended for this washer, Hobart AM14? David Jackson
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hobart AM14-253 Free-standing...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
