Question about Presto HeatDish Compact Heater
Broken knop i think the heat knop doesnt turn it on
    Problem Solver:
  • 18 Answers
Sounds like you got milked buy another
Posted on Jan 04, 2008
Hi my tecnogas oven take a wile to lite up you must keep it in for 1 min it burns but when you release the knop it goes out the flame
Try cleaning the tip of the wire that is near the flame nozzle...that is the heat sensor (thermocouple) which waits to get hot before it allows the gas to flow to the nozzle (safety measures) without the need for anyone to hold in the knob.If the wire is dirty or two short the gas will just stop once you release the knob.
Dec 16, 2017 | Heating & Cooling
How to remove selector knob from bosch hammer drill gbh 2-20 s
Take a little screwdriver under the knop and jump him out BUT be carefull there is a little metal pin inside the knob that can be loose and easy lost .
And important Jump out the knop (BEFORE) you have removed the 4 screws of the black house.
Jan 09, 2016 | Bosch Drills
What might be wrong with my Kenmore dryer which doesnt heat? The drum turns but doesnt heat.
Could be the element has broken very simple fix. Here is my home made video which shows how to repair the machine:
My youtube channel has your service manual in one of my blogs on my about page. have a good un -PawPaw
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 29, 2014 | Dryers
Ik heb de codes nodig voor een universele afstandbediening voor mijn samsung hitron black tv
Hallo
Driecijferige universele afstandsbediening codes voor Samsung tv zijn:
004 / 005 / 009 / 015 / 104 / 105 / 106 / 109 / 133 / 172
Viercijferige codes universele afstandsbediening voor Samsung TV zijn:
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Direct Code Entry
1 * Houd de SETUP knop ingedrukt tot het rode lampje blijft branden, laat dan de SETUP knop.
2 * Druk op de gewenste knop Modus (TV, VCR, etc.). Het rode lampje knippert, dan blijft branden.
3 * Voer de 4-cijferige code uit de code tabellen. Let op: na een geldige code, het rode lampje uitgaat. Voor een ongeldige code, het rode lampje knippert.
4 * Met uw apparaat, druk op pijltje omhoog. Als het apparaat reageert, is er geen verdere programmering is vereist. Opmerking: Als sommige knoppen niet bedienen apparaat, een van de andere codes voor uw merk proberen. OK
Jul 16, 2011 | Televison & Video
My dryer doesnt work. the tumbler doesnt turn. when you push the start button it sounds like its going to start but it doesnt move
hi check the belt maybe broken or if you just hear humming maybe motor. dose it heat at all? jim
Oct 11, 2010 | Maytag Dryers
The dryer doesnt rotate. it turns on and heats but doesnt rotate?
your drum belt is broken,you need to remove the top and front cover to replace this belt
Jul 25, 2010 | Kenmore 63942 Dryer
My ACL lifestyle lp522 doesnt turn heater off
Hi it sounds like it hs worn inside exchaning it would be the cheaper option
Feb 01, 2010 | Honeywell Programmable Thermostat Heater
Wais de aos Knop / waarkan ik die vinden?
I don't know what language you're using!
You talking about the aoss button?
Well... here... near the right side of you psp if it is new there should be a small button near the power button that is the aoss button!
Nov 25, 2009 | Sony PlayStation Portable (PSP) Console
What do i do to clear the ''rinse machine'' message?
Fill up the water tank 150%
Turn the "Milk" knop and have two cups underneath that you can empty regulary. Then just wait and the machine will say Rinsing Finished.
Fill up the water tank completely again, and the machine will ask. "Clean Water" press the big cup knop.
Then the machine should say, *SELFTEST*
Nov 12, 2008 | Miele CVA615 Espresso Machine
PANASONIC KX-A144EXS
druk middelste knop ,nr verschijnt !
druk ronde knop rechts,
druk ronde knop naar beneden tot WISSEN verchijnt en druk dan ronde knop rechts en kl is kees
Sep 06, 2007 | Panasonic KX-T7730 Corded Phone
Presto HeatDish Compact Heater Logo
Top Presto Heating & Cooling Experts
Mack Baxter
Starnley Johnwells
Starnley Johnwells
Paul Carew
Are you a Presto Heating and Cooling Expert? Answer questions, earn points and help others
