- the red and blue converge works. the green will move in all directions but "next" is slanted on the green converge screen
Nov 05, 2009
- Thanks so much for getting back to me. The blue and red will move and line up correctly. It's the green that is messed up. The green slants up on left side of words and pictures but is normal on the right side?
Can you help? I just don't want to buy a convergence kit if that's not the problem.
Go INTO the customer menu and select CONVERGENCE--what you are looking for is will blue or red not move in some direction?
If
you find in your case blue OR red is wacked and will not adjust let me know--I
can post here start to finish instructions for this repair on this
set.....
You only need to be able to know how to solder and get
at the chips--you can buy a pair of the chips on Ebay for less than 14
dollars plus shipping.
If you cannot do it yourself--let me know and I will give you options.
I am here to help people--if this information helps you rate this solution--I do this here for free.
SD TECH
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
Quick feedback with helpful questions.
" - strawberri07
Lower half of the screen has a blue smear all the way accross. I swapped the blue & green...
(More)
Lower half of the screen has a blue smear all the way accross. I swapped the blue & green and it turned into a green smear so I think the tube is OK.
I have an Panasonic PT-53WX52 53 in. Rear Projection Television that will not turn on. There is a...
(More)
I have an Panasonic PT-53WX52 53 in. Rear Projection Television that will not turn on. There is a red LED power indicator in front that is flashing 3 times every 5 secends.
A friend of mine gave me this television for free. The problem is from the day he purchased it the...
(More)
A friend of mine gave me this television for free. The problem is from the day he purchased it the picture has been very dark and not so crisp. I have running on satellite and even DVD and the picture isn't great. All the colors seem fine and the covergence crosses all match up. I've even turned up the Brightness and had no luck. Can anyone help???
