GE DCVH515EF Electric Dryer
Problem for GE DCVH515EF Electric Dryer
Dryer is making a sand like noise
By snakehips111 on Nov 03, 2009
dryer is making a sand like noise
Solution #1
posted on Nov 03, 2009
Not Rated)
hunter19_46m
Rank: Guru  GE Washers & Dryers  Expert
Rating: 91%, 300 votes
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication,
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see the belts condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Was this helpful?
Yes
No
Popular Solutions for GE DCVH515EF Electric Dryer
Questions and Unsolved Problems for GE DCVH515EF Electric Dryer
Do you recommend GE DCVH515EF Electric Dryer?
Answer
Answer
how to open dryer
Answer
what does D70 mean?
Answer
GE electric dryer DCVH515 light comes on but panel will not light up and can't use it at all
Answer
GE Frontload Dryer (DCVH515EF model) starts up and heats up just fine, but the dryer turns off after... (More)
Answer
hello the problem with the dryer is that it display an E01, which i have to assume is some error... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryer Experts
Top Washer & Dryer Repairmen
in , CA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
