Remove the outer cover and look for a blown fuse. Change the high voltage diode (pull the power plug first) and the 'stirrer' (a fan-like device located inside the sheet metal waveguide near the port where the microwave energy enters the cooking cavity). It's plastic bearing will arc-over causing a short circuit on the microwave energy.
I have a JES 1456 GE Sensor microwave oven purchased at Walmart about 3 years ago. It has worked...
(More)
I have a JES 1456 GE Sensor microwave oven purchased at Walmart about 3 years ago. It has worked great up until now and it just quit. It is blacked out and does nothing. It quit without a sound while in use. No sounds. no smells. nothing. I played with it for a while pressing all the buttons, opening and closing the door and once it lit up but when we went to use it, it blacked out again.
I purchased a GE JES1456WJ from a homedepot. I used it to boil some water and the top of the...
(More)
I purchased a GE JES1456WJ from a homedepot. I used it to boil some water and the top of the microwave became so hot I couldn't touch it. I exchanged it for another one. And the same thing is happening. I can't say I think this would be normal would it? The top is hottest in the top back area near where the power cord enters the machine.
I have a GE spacemaker Microwave oven. And after canning pears I notice the door had white dots...
(More)
I have a GE spacemaker Microwave oven. And after canning pears I notice the door had white dots between the glass. How can I clean them off for it is black and shows them like beacons of lights. Carolabeer@hotmail.com
