Canon PowerShot SD600 Digital Camera
Problem for Canon PowerShot SD600 Digital Camera
Error msg during power up of Canon SD600
By tswatson on Nov 03, 2009
When I power on my Canon SD600, I get a series of beeps and a "lens error, restart camera" message. Any suggestions on how to resolve?
Solution #1
posted on Nov 04, 2009
Somewhat Helpful)
StephanSA
Rank: Guru  Canon Cameras, Camcorders & Accessories  Expert
Rating: 92%, 338 votes
Hello
This is a very , if not the most common problem with modern digital camera's.
Most of the time the problem is that sand , dirt and grit gets lodged in the camera lens barrel thus keeping it from extending properly but could also be caused by a drop or a hard knock on the camera.
Firstly , the odds are not with you on a DIY fix so don't be disappointed when the following steps do not work.Nevertheless , some people have fixed their camera's using the following steps.
Use these at own risk as it may further damage the camera.
Firstly try charging your batteries overnight and then try the camera again tomorrow.
Try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
These 3 options provide your camera with more power available to the extension mechanism which could overcome some of the particles that are lodged in there if there are any.
Try using compressed air (best is a clean air can bought at a electronics store) and blow between the lens and the casing. This should help dislodge some of the particles.
Look at the lens , and if some of the lens 'circles' are misaligned or not concentric then try wiggling it (while holding camera lens down) so that some of the particles can escape. Also try moving the lens away from the side with the biggest gap (also upside down)
Try gently pushing or pulling the lens when it tries to extend but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
As a last resort if you decide to replace the camera try hitting the camera near the lens with increasing force with the palm of your hand. Between each hit , try using it again.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise works. Good luck and don't hesitate to contact me if you need further assistance or information.
Regards
Stephan
Was this helpful?
Yes
No
Popular Solutions for Canon PowerShot SD600 Digital
Questions and Unsolved Problems for Canon PowerShot SD600 Digital
Do you recommend Canon PowerShot SD600 Digital Camera?
Answer
Answer
Canon SD600 when setting the switch to the upper position for single shot mode, it slips down to the... (More)
Answer
canon sd600. the lens doesn't open completely.. how do i fix it?
Answer
Canon sd600 3 years old -- photos are blury. professional photographer suspects it is a processing... (More)
Answer
my camera won't power on
Answer
The camera will not turn on. We have a fully charged battery and also tried turning it on while... (More)
Describe your Digital Cameras problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Camera Experts
Top Camera & Camcorder Repairmen
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(316) 832-9484
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
