I have a netbook by HP with a built in webcam and for some reason, it now says cam not installed and I can't get it to work and when I look for the drivers they don't show up anymore? How do I fix it?
Go to www.rapidlibrary.com Search for a program called ( Driver Scanner) Download and install it , It will find the webcam driver so that it will work.
It says my screen resolution is too low for the printer to work. I can't change the resolution on my...
(More)
It says my screen resolution is too low for the printer to work. I can't change the resolution on my computer.
roxio and cyberlink DVD software are asking me to reset my display setting. but system is showing a...
(More)
roxio and cyberlink DVD software are asking me to reset my display setting. but system is showing a plug and play monitor is active and the setting that meets both copy software company minimum settings. but it looks like when both companys software trys to open they only see the default monitor setting of 800 x 600 at 8 bits ? even when I attempt to change the resuluion I hit the apply button and the setting goes right back to 8 bit setting, I can not change that on my netbook to a higher bit rate even though it has both 16 and 32 bit showing HELP !! I would love to use the CD/DVD software.
1. is the 1120nr bluetooth equipped? 2. how to set up printer, or access a printer thru local...
(More)
1. is the 1120nr bluetooth equipped? 2. how to set up printer, or access a printer thru local network?
