Olympus FE-280 Digital Camera
FE-280 Olympus
shared by 2 users
posted by jim_ijn on Jan 04, 2008
Please isn't there anyone after paying $10 who can tell me anythign i didn't already know and help me to get the computer to recognise the camera
Comment posted on Jan 04, 2008
I tried the Premium plan and got no more information than was in the basic manual, which i had already read
Dear Leo2
Do you mean with the camera still turned on? I definitely had it in review mode before I tried earlier.
Kind regards,
Jim
Same issue Leo2
I tried it with the camera on, folloed the instructions. It is not a matter of the camera. It's something in the Device management software within Vista. The dirver has loaded but the device is not registering properly.
Thanks again
Jim
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by richard35 on Feb 22, 2008
I have the same problem with my FE 280. XP Pro just doesn't pick up the driver correctly, and always says the device has malfunctioned. Device Manager it show up with the yellow mark and no amount of reinstalling deleting will make it work properly. Very frustrating
Richard Warden
Best Solution
Helpful (85)
Soulvisitor
Rank:Guru Guru
Rating: 88%, 1566 votes
u did see this after pic below, and you have tried deleted usb controllers in device manager then reboot can u tell me if, cam lights up/does windows make a connection sound, when usb from cam is connected? posted by Jordiane on Nov 18, 2007 Report abuse
It says it is unable to find a camera connected to the USB ports. Any idea where I could find a driver to help this or is it another problem?
Have the same problem? Click Here
6 Other Users Have The Same Problem Comment by Emilie, posted on Nov 21, 2007 The display doesn't turn on when the camera is turned on unless I switch the mode on the dial. The camera turns off when I toggle the zoom.
Comment by Guest, posted on Nov 29, 2007 Zoom does not work
Comment by Guest, posted on Dec 27, 2007 I receive the message the software was unable to find an Olympus digital camera conected to a USB port on your computer.
Comment by petedrum, posted on Dec 23, 2007 Same Problem. Tried it on two XP computers, can't find camera on either. Camera lights up when plugged in.
Comment by Kellib, posted on Jan 01, 2008 I'm having the exact same problem with my camera. i can't figure anything out with it and if i plug the usb into the computer, i hit ok for PC and then my computer freezes. someone please please help me figure this out
View All Best Solution posted on Dec 24, 2007
Mickoolz
Rank: Apprentice
Rating: 70%, 3 votes
I had this same problem, I'm using Vista on my HP laptop and I managed to correct it. Apparently HP like to customize Vista and when connecting some USB device's they don't recognise them as what they should. A USB mass storage device. You will need to connect the camera to the computer, the camera will come on then click the ok button so it selects PC. Wait until it finishes its search click cancel and open device manager, scroll down and below Network Adaptors you should see an expandable tree with an yellow exclamation mark named Portable Device's --> FE-280/X820/C520 you will need to right click on the FE-280/X820/C520 icon and select "Update driver software". Then select "Browse my computer for driver software" then select "Let me pick from a list of device driver's on my computer" Scroll down till you see "Universal serial bus controllers" then select "USB Mass storage device" in the next window. It should all work fine now! If it still doesn't work try selecting "Portable devices" then select "WPD File system device" --> "Microsoft WPD filesystem Volume Driver".
Hope it helps.
Cheers, Mick
Was this solution helpful? Show your Appreciation by rating it:
LINK to Micks post above
Thank You!
Was the solution helpful?
Show your appreciation by commenting on FE-280 Olympus:
I don't want to Accept this solution
Solution #2
Thanks for Trying (70)
leo2
Rank:Wiz Wiz
Rating: 80%, 575 votes
set your camera to "preview "not in camera or video press on camera , hook USB cable to camera and then detection desplay by computer and camera it will appear the computer screen , just follow instruction.
Rating Locked! (?) jim_ijn has rated this solution as Thanks for Trying
Thank You!
Can you Help with these Digital Cameras problems?
pc not seeing my camera also registration not being seen...
When connected by cable to PC, Camera should switch on...
When ever I go to download my pictures the camera wants to...
I took 3 pictures with the camera set on the wrong setting...
the camera will not take any pictures when i have the...
Loading problems.
Repair Service
Find Digital Camera Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
