Question about Kitchen Appliances - Others
The rice looks like plastic
Hello there, I would like to know if you can tell me why the bottom of my rice looks like plastic. This is my first rice cooker and I have no idea of my its happening this. All I do, its put 1 cup of rice and 1 and a half cup of water in my rice cooker and turn it on, and when it tells me that the rice its ready, the top part of the rice looks really good, but when you look at the bottom part, there is a little hard plastic-looks like thing. Can you help me please ?
  • 3 Answers
Http://www.fixya.com/support/t85559-need_tips_using_salton_rice_cooker
Posted on Jun 24, 2009
    Problem Solver:
  • 7 Answers
Try putting one cup of uncooked rice to one cup of water (rather than a cup and a half of water). Also, to keep the rice white longer, you can add a few drops of white vinegar to the rice and water mixture before you turn it on. Hope this helps!
Posted on Dec 28, 2008
How do I clean the drain filter assembly on may tag dishwasher mdb4651awb
Sometimes this can only be gotten to by unscrewing the bottom spray arm in the basin of the DW. First, look in the bottom of your DW to see if you can unclog the screen by hand. This is the Drain Filter Assembly. It screens the waste so the pump doesn't get clogged. If you swipe stuff on the bottom of the DW like that leaf lettuce and rice, this might help.
Is their debris in air gap or in the bottom of the DW, where the drain is screened?
1. The air gap is usually located on top of the sink. Lift off the pretty cover, and unscrew the top cap nut. Is there rice and debris there? Remove it then. Reassemble and check it out.
2. The DW drains to the bottom of the unit where the pump is. This area is screened off so that the pump doesn't get clogging debris in it. is their leaf lettuce and stuff covering this? Remove that debris. Some times this area can only be accessed by removing the bottom spinning spray head. It comes off with a nut, possibly this nut is reverse thread. Reassemble when done looking for debris.
3. Is the drain line between the DW pump (located under the DW) and the waste pipe kinked? This line is a plastic corrugated line about 7/8" around the outside. It is a pumped waste and won't work if it is kinked, so unkink it.
4. Is the float stuck. This is a device on the bottom of your DW that tells the DW how much water is in the bottom of the DW basin. It looks like a mushroom. Gently move it up and down. Does it move freely or is it stuck? Unstick it.
Good luck.
Nov 03, 2013 | Dishwashers
I was trying to clean my coffee grinder and when I took the bottom off a clear plastic came out and I can't get it back in.
see the steps:God bless you
  • Unplug the coffee grinder and wipe out as much residue as possible with a paper towel or clean cloth.
  • 2 Plug in the grinder. Add a little dry, uncooked rice to the grinder and turn on the grinder. Grind the rice until the grinder no longer has an odor or until the rice is finely ground. Repeat this step if necessary.
  • 3 Unplug the grinder and remove the ground rice completely. Wipe again with a paper towel or clean cloth.
  • 4 Hand wash any removable lid to the coffee grinder with dishwashing liquid. Allow to air dry.
  • 5 Clean the exterior of the coffee grinder with a damp cloth or paper towel
    however download your instr.manual www.fitness.manualsonline.com
  • Sep 24, 2012 | Coffee Makers & Espresso Machines
    I lost the plastic measuring cup that came with my Rival RC100 rice cooker, the markings on the inside of it tell's me the water amount I just need to know how much rice the cup held.
    The measuring cup you lost is equivalent to 3/4 cup or 180ml and this can make approximately 2 and 1/4 cup of cooked rice.
    http://
    For more details, you can download Owner's Manual at www.rivalproducts.com ,
    You can also inquire on this site about cup replacement.
    Regards.
    Jun 23, 2011 | Rival RC100 10-Cup Rice Cooker
    Plugged in cooker but will not come on
    hello what you need is to fill up the black area with water
    what i mean is that you will put in water in to the pot above the black area to stock up the burnt rice for some time.then you wash it off the problem is solve .
    thank you and thanks for using fixya.
    Jun 08, 2010 | Panasonic SR-42F 23-Cup Rice Cooker
    Need sunbeam/oster 4713/5710 rice cooker directions
    All you have to do is pour white vinegar in the bottom, leave for about 2 hours and rinse and wipe clean!
    Mar 20, 2009 | Sunbeam Kitchen Appliances - Others
    Replacement basket for Black & Decker HS800 Flavor Scenter Rice Steamer
    I would not recommend replacing just the plasic basket, too expensive. Once the plastic parts begin to fail, the uint has seen better days (our basket was still ok, but the unit started to leak out the bottom and the timer would stop during the steaming).
    Bought a replacment B&D Handy Steamer, oval shape allows longer food items to be steamed (approx 10"x8"), water res & can be filler while steaming. Price was $25 in local hardware (Jan 09). Not worth fixing the old one IMO.
    Apr 14, 2008 | Black & Decker HS80 Rice Cooker
    Cooking Rice
    Ironically, I came to this site with the same questin you posted. I just found my manual. This is how tha manual tells you to steam rice:
    Place one of the steamer baskets on the steamer base.
    Place 1 cup of rice and 10 ozs of water in the rice bowl.
    Place the rice bowl on the steamer basket and cover the steamer.
    Set timer for approximately 32 minutes, depending on your taste.
    Sep 24, 2007 | Tefal 61605 Steam Cuisine Rice Cooker
    Cover latch
    You may need to tighten the screw for the metal post where it's held to the top lid. This should help to extend the metal post to reach over the plastic latch, enough to latch down the lid.
    Apr 11, 2007 | Tiger JNP-1000 5.5-Cup Rice Cooker
    Kitchen Appliances - Others Logo
    132 people viewed this question
    Top Kitchen Appliances - Others Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Irene Tulloch
    Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
