Removable Media
Problem for Removable Media
Generic problem for all Removable Media
My USB Memory stick wont show on My Com...
By egor94 on Nov 03, 2009
I have a usb memory stick which wont show on My Computer. The LED does not light up. I checked on lots of computers but still wont work. I like my memory stick and I cant buy a new one because its soo old. Can the memory stick be repaired?
Best Solution
posted on Nov 03, 2009
Very Helpful)
StephanSA
Rank: Guru
Rating: 92%, 215 votes
There is normally one of two things that goes wrong with a memory stick.
Either the usb connector's soldering onto the board fails or the flash memory itself fails.
If the flash memory itself has failed you will not be able to repair it , but if the usb connector came loose, it will cost about $5 at any repair shop to correct if they don't do it for free.
You can also open the casing up and solder it yourself as the soldering is normally quite big.
Kind Regards
Stephan
Comments:
Nov 03, 2009
- It's a pleasure, let me know if you need some help doing it yourself.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thank you very much, very helpful. " - egor94
Solution #2
Not Rated)
brladewig
Rank: Guru
Rating: 85%, 66 votes
I'd try in different USB ports and even maybe on another computer first. If still not working, contact the manufacturer. If you truly mean 'Memory Stick', as in Sony's, you can find support options for repair or replacement. Alternately, you could attempt to go through a data recover specialist.
Was this helpful?
Yes
No
Popular Solutions for Removable Media
Questions and Unsolved Problems for Removable Media
Answer
Windows 7 upgrade or full ?
Answer
How do I get my pic's off my computer on too the flash drive so I can put them on my pic fram
Answer
my little one has the cube and did not come with software. and when i try to format it it says... (More)
Answer
how do i open the mini attache usb 2.0 flash drive
Describe your Removable Media problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Removable Media Experts
Top Computer & Laptop Repairmen
in , MD
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
