Double-check your flash settings. You mentioned the camera is in Auto mode, but the flash has separate settings from the camera's shooting mode. With the camera in shooting mode AUTO check the Flash settings (Auto, Red-Eye Reduction, Fill-In, Off) It may be set to 'fill' causing your photos to be too bright. Also, depending on how close you are to your subject the flash may not be needed. Using the flash when too close to your subject (less then 3 ft.) will cause bright/white photos. Turn the flash OFF if you are taking macro or photos closer then 3ft. If neither of these fix your problem, turn the flash mode OFF, and camera shooting mode to AUTO and in a naturally well lit area, take a photo, if the photo is still too bright, you may have something mechanically wrong with your camera.
Was this helpful?
Yes
No
Popular Solutions for Olympus FE-210 Digital Camera
olympus FE-210 the camera when I turn on, the screen is always brighiant, white, I'm use...
(More)
olympus FE-210 the camera when I turn on, the screen is always brighiant, white, I'm use rechargeable batteries please I need help
olympus fe-210 camera shoots three or four pictures and then the screen goes black and the rest of...
(More)
olympus fe-210 camera shoots three or four pictures and then the screen goes black and the rest of the pictures are black. If you turn off the camera for an extended amount of time it will take a few more pictures and then go black again
(More)
olympus fe-210 camera shoots three or four pictures and then the screen goes black and the rest of the pictures are black. If you turn off the camera for an extended amount of time it will take a few more pictures and then go black again.
after i put all the pictures in computer then i charge the battery, then after i full charge the...
(More)
after i put all the pictures in computer then i charge the battery, then after i full charge the batt . i try to put it on my digicam and try to open it.. but it doesnt work, even i try other brand of batteries.
