Question about Roper RES7646KQ Electric Dryer
9 year old whirlpool dryer won't start
- light is on timer works,wiring and fuse is fine - could it be the on switch?
  • 90 Answers
Bad thermal fuse at blower housing.
Posted on Jan 06, 2008
Dryer won't start, light is off, but fuse is ok
Had a similar situation after running the dryer for multiple loads. I checked the wiring schematic and found the overload thermal switch location on the exhaust duct. Using my $4 volt amp meter I checked and found the circuit open (the switch open circuit). Removed the switch, went to the appliance parts store and bought a replacement for an exorbinant $9. Installed the switch and it has worked for the past couple of years.
Now that was my solution. You will need to check the wiring diagram for the problem. I would not buy a new dryer just yet until looking for a simple switch or contact that isn't working.
Dec 20, 2012 | Whirlpool LEB6300 Electric Dryer
Troubleshooting whirlpool electric dryer WED5530SQ0
The only thing that is left is the timer. Use a multimeter and wiring diagram prior to replacing it. It is something that doesn't go out often.
Good luck.
Semper Fi,
Z
Feb 01, 2018 | Whirlpool Dryers
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
I have a 70 series Kenmore dryer model # 66722694 it heats fine and runs fine but it cuts off for no apparent reason. after letting it sit or cool down for 15 to 20 minutes, it starts back up. i removed...
sounds like you have a bad heat sensor bypassing your fuse is an open invation to start a fire its there for a reason it also sounds like your timer is bad you might consider a new dryer dependimg on how old it is
Jan 19, 2011 | Dryers
My Whirlpool dryer(supreme) does not start. The timer switch, door switch, start switch can all be heard to electronically switch on and off when I turn the timer around and open and close the door....
the thermal fuse may be faulty. Remove the outer back of the dryer. the thermal fuse is located on the blower assy with 2 wires connected to it. It is white plastic. connect the wires together, then try to start the unit again. If the unit starts, clean the exhaust duct after replacing the thermal fuse.
Jul 20, 2010 | Whirlpool LEQ8000JQ Electric Dryer
My dryer wont start. The fuse box is fine and the
The belt is probably broken . This unit won't start if the belt is broke.
Oct 10, 2009 | Whirlpool GEQ9800P Electric Dryer
Dryer worked for two days
Yes, you did. I advise you to either call me here Whirlpool Parts Surplus OR get a new pigtale for the dryer. AND a thermal fuse. Take the 9-11 1/4" screws out you will see a white skinny fuse straight down off the outgoing air duct. check continuity or connect the wires. I advise you to get a new cord before you start it again.
Best of luck
Mark
Apr 13, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer will not start when I press the start button.
frist check the door switch in sure it is working if it is good unplug the dryer remove the back cover where the vent comes out there is a little white fuse with 2 wires on it. it is oblong and most of the tim the 2 wires are blue replace this fuse and your dryer should work fine.
Jan 19, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Roper RES7646KQ Electric Dryer Logo
103 people viewed this question
Top Roper Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Roper Dryer Expert? Answer questions, earn points and help others
