Question about Kenmore 64892 Electric Dryer
Signal how to turn off end of cycle signal on dryer
  • Anonymous Nov 30, 2008
    same issue here. exact same issue and its really annoying having to start a 100 meter dash to stop the signal once the clothes are done
Kenmore 70 series. Model/Stock 66702692 Serial MG2402832
Cycle Signal works but then won't shut off until I open up the dryer door - it just keeps buzzing for hours. Also the dryer will turn on if I close the door ( and arrow is within a number and not on off) without pressing the start button. So if door is closed - the dryer will run or buzz (depending on arrow). How do I fix this?
Thank you
Posted on Nov 25, 2008
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
How do I turn on bell on my dryer
From the Whirlpool user manual:
(OPTIONAL) Your dryer may have an End Of Cycle Signal. The
signal is helpful when drying items that should be removed
from the dryer as soon as it stops.
On some models, the End of Cycle Signal is fixed.
On other models, the End of Cycle signal is part of the
Start button and is selectable. Turn the PUSH TO START
button to ON or OFF. The signal will sound only if the
selector is set to On.
Jan 22, 2016 | Dryers
How to shut off dryer end of cycle beep. Can u run
If the model number is correct, the dryer End of Cycle signal cannot be adjusted or turned off. The informatrion is listed on page 11 of the Owner's Manual:
http://www.managemylife.com/mmh/owner_manuals/16695/WHIRLPOOL-Laundry-Centers-L0710382?brand_name_search=LTE5243D
The only way to turn the signal off, is to remove the operator console, locate the signal (buzzer) module and disconnect the wire(s). The buzzer is listed as item 32 under the "Washer/Dryer Control Panel" parts listing:
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-dryer-combo-Parts/Model-YLTE5243DQ2/1198/0152000/W0702346/00001?blt=06&prst=&shdMod=
CAUTION: If you choose this option, make sure you UNPLUG the washer/dryer before servicing anything inside. If you disconnect any wires, make sure you cover them with heat shrink or electrical tape to keep them from coming into contact with anything else.
The washer and dryer use a common power source, but the rest of the functions operate independently of each other. You can safely run both units at the same time.
If need further assistance, please let me know. I hope this helps you.
Aug 09, 2011 | Whirlpool LTE5243D Top Load Stacked...
Om dryer says control lock
Press and hold the End of Cycle Signal button for 3 seconds or until the Control Lock indicator turns off to unlock the control. This button actually has the marking below it that says " Hold for 3 Seconds to Lock/Unlock Control". You have to check the control for any stuck button and unstuck it if the control still cannot be unlocked with the End of Cycle Signal button and unplugging the dryer for at least 15 minutes. Let us know if the problem persists.
Jul 18, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
How can i fix my dryer. I it stuck on control lock
Press and hold the End of Cycle Signal button for 3 seconds or until the Control Locked indicator turns off to unlock the control. This button actually has the marking below it that says " Hold for 3 Seconds to Lock/Unlock Control". You have to check the control for any stuck button and unstuck it if the control still cannot be unlocked with the End of Cycle Signal button and unplugging the dryer for at least 15 minutes. Let us know if the problem persists.
Jul 13, 2011 | Whirlpool GEW9250 Electric Dryer
How do you turn off the control locked key?
To enable the Control Locked feature when dryer is
running:
Press and hold the END OF CYCLE SIGNAL button for
3 seconds. The control is locked when a single beep is heard and
the Control Locked status light is on.
 When the dryer is off, it is not necessary to press the Control
On button before activating the Control Locked feature.
To unlock:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds
to turn this feature off.
NOTE: When the dryer is running and Control Locked is on, the
dryer can be stopped by pressing the Pause/Cancel button, but
can’t be restarted until the control is unlocked.
May 29, 2010 | Whirlpool GEW9250 Electric Dryer
63942 Dryer: how do you turn off the dryer signal on kenmore 70...
Hi, you can turn the signal off by using the start button on the dryer (located on the right side of the panel under the words "Push to start dryer"). Turn the knob to the left to turn the signal off, or to the right to turn it on. Each side should be labeled, but the lettering may have worn off over time.
If you've turned the knob to the left and it still signals at the end of a cycle, the switch that controls the signal may be broken.
May 18, 2010 | Kenmore 63942 Dryer
Kenmore dryer beeps constantly
End of Cycle Signal
The End of Cycle Signal produces an audible sound when the
drying cycle is finished. Promptly removing clothes at the end of
the cycle reduces wrinkling.
@ H_GH
@ LOW
@ OFF
END of CYCLE S_GNAL
Press END of CYCLE SIGNAL to adjust the sound level or turn off
the signal.
NOTE: When WRINKLE GUARD _ is selected and the End of
Cycle Signal is on, a tone sounds every 5 minutes until the
clothes are removed, or WRINKLE GUARD _ ends.
Sep 15, 2009 | Dryers
WHIRLPOOL DUET GAS DRYER CONTROL LOCKED ON.
Hold down the end of cycle signal botton for three to five sec that should turn that off good luck
Apr 11, 2009 | Dryers
End of cycle signal
if the buzzer is on the main board you may not be able to disconnect it.is ther any buttons that turn it off.
Feb 24, 2008 | Bosch Classixx WVF 2402 Front Load...
Kenmore 64892 Electric Dryer Logo
328 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
