Acer Aspire 3680 Laptop/Notebook 80GB 14-WXGA Vista HomeBasic 9980286710 PC Notebook
Problem for Acer Aspire 3680 Laptop/Notebook 80GB 14-WXGA Vista...
Hi, i'd like to have some instructions on how to
By woodsc on Nov 03, 2009
Hi, i'd like to have some instructions on how to replace the keyboard on my acer 3680 ,thanks
Comments:
Nov 03, 2009
- No, I'd just like some instructions on how to , I ordered a new keyboard, and am waiting for it to arrive. An external usb keyboard works fine, so I figure I have to change mine some of the keys don't work anymore. thanks
Nov 03, 2009
- I guess my request was more directed at the hard part for me which would be how to disconnect that ribbon cable without ruining the motherboard, and replacing the new ribbon, thanks
Clarification Request
Posted by troy9181 on Nov 03, 2009
have you tried to take it apart yet?
Solution #1
posted on Nov 03, 2009
Somewhat Helpful)
Fixe_You
Rank: Wiz  Acer Expert
Rating: 82%, 1018 votes
Hello.
Glad to Help You.
There should be a panel above the keyboard that is usually held in place by a series of tabs. You will need to pry it up. Starting from one corner, gently lift it until you can remove the entire panel. If it seems overly difficult, look around the LCD hinges for screws, some laptops have them. You should find that the keyboard is held in place by 2 - 3 screws at the top, remove these screws, lift the keyboard, whilst being careful with the ribbon connector.
Attention! Be very gentle with the keyboard connector on the motherboard.
f you break the keyboard connector, you’ll have to replace the entire motherboard or use the laptop only with an external keyboard.
Good Luck.
Comments:
Nov 03, 2009
- Hi there.
Remove the laptop battery and the AC power supply, open the lid as far back as you can take it.
Get a small flat headed screwdriver, now, you have to take off the keyboard bezel, this is the strip of plastic above the keyboard with the power button on it, the best way to remove it is to start by the on/off button by gently prying the bezel up from the lid hinge, once you have one side out gently pull it up using your fingers, it will unclip and lift away.
Next you have to remove 2 screws from the top of the keyboard, these should be visible to you, once the screws are out carefully lift the keyboard up, you will see a ribbon cable that is connected to the motherboard, gently pull the tab up on the connector that the ribbon cable sits in and it should release it and you can now remove the keyboard and replace it.
To re-assemble just follow my direction in reverse
Nov 03, 2009
- just as an additional help
here is the service Guide for acer Aspire 3680.
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 3680
Questions and Unsolved Problems for Acer Aspire 3680
Do you recommend Acer Aspire 3680 Laptop/Notebook 80GB 14-WXGA Vista HomeBasic 9980286710 PC Notebook?
Answer
Answer
Acer Aspire 3680 Laptop/Notebook 80GB 14-WXGA Vista Acer Aspire 3680 will not boot up Answer Acer... (More)
Answer
Hello Is there a way for me to down load recovery disc for Accer 3680-2682.
Answer
bootmgr missing on a acer 2930z. Havve no reboot disc etc. plz help...
Answer
isatap #14, 15,16 is flaged on the computer. what does that mean...does it have anything to do with... (More)
Answer
i have problem with my ctrl key it is always pressed example when i press only (F)then its open find... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Aspire 3680...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
