Dell Vostro A860 Notebook Logo
Posted on Nov 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I got my dell vostro a860 in june 2009 ...now my problem is taht my cd/dvd doesn't work....sometimes i see it in my computer and device manage/but sometimes i don't...I bought 2 dell vostro A860...on one everything is perfec...on the other the cd/dvd rom is the problem....on both laptops i installed windows XP...
Anonymous
Level 3:
  • Master 3,940 Answers
  • Posted on Nov 04, 2009
Anonymous
Master
Level 3:
Answers
3940
Questions
0
Helped
1404373
Points
12062
First try this fixit tool
http://support.microsoft.com/kb/314060
If that doesn't work, try swapping the drives between the systems and see if the issue follows the drive. If the issue follows the drive, replace it.
If the issue stays with the system, then it is either SW (the fixit link should help) or the MB contacts for the drive are bad.
My DVD/CD-RW drive isn't recognized/ doesn't play disks.
It may be bad. Has the laptop been damaged? Dropped? Open Device Manager, DVD/CD Rom drives, is it listed? In Start Menu, Computer, Is it listed? Try re installing the DVD rom driver, the MS Vista 32bit drivers can be found here: http://www.dell.com/support/drivers/us/en/04/Product/vostro-a860
tip
Dell vostros 220 cd/dvd drive not working
my cd/dvd drive quit working device manager showed the triangle and ! mark, properties showed code 10. shut power off, took side case off, unpluged both cd/dvd's, from the board, restarted machine let it reboot, shut power off again,plugged both cd/dvd's back in, restarted machine, both were reinstalled and now working. hopes this is some help to somebody else. thanks jim.
Problems hl-dt-st dvdram gsa-t40n ata device
Dvd needs replacing sometimes they just fail, like you can have hard ware and not software the reverse also applies
dvd are cheap enough now
2helpful
I have a dell vostro A860 laptop.not working to Touchpad. How to Fix Touchpad Not Working in Laptop
What you can initially do is to update the driver.
  1. Press on the windows key + R. A run box will appear.
  2. Type devmgmt.msc then click on ok. The device manage will appear.
  1. Click on the plus sign besides mice and other pointing devices.
  2. Right click on the item that will be pertaining to your touch pad.
  3. Choose update driver and let the internet work for you.
If this does not work, you will need to totally reinstall the driver.
  1. On the same screen (device manager) right click on the touch pad driver again, the choose uninstall.
  2. follow the prompts for uninstallation. You might wanna uninstall any mouse related drivers as well (these application can also cause conflicts thus causing your touch pad not to work)
  3. download the touch pad driver available from the link I provided below.
  4. follow the prompts for installation.
  5. restart
Dell Vostro Driver list (click here to view all available drivers for your portable system)
Dell Vostro Touch Pad Driver (click here to download the touch pad driver)
It this does not work, you will need to call Dell Technical Support to have the laptop serviced. That is if the portable still has warranty. If not, then you will need to buy a USB mouse as a replacement.
for additional information visit Dell support website: support.dell.com
1helpful
I want to install audio driver on my laptop dell vostro A860.but every time failed due to not available media device. window xp
look in device manager, if you see a red x or a yellow sighn it may not be turned on ? or the device could be bad ? you might nedd a new sound card ? hope this helps !
Wireless led didnt work on dell vostro a860 after win 7 install
install the proper drivers from the cd/dvd given at the time of purchase
DELL VOSTRO A860...PUT VIDOE CLIPS & PICS ON DVD-R
click start, go to computer, right click the dvd icon and select format, format as a data disk and try burning again..
if the back of the dvd-r has two shades then its already been used and can't be used again.
1helpful
Disk detection On and Off
You could have a partially defective hard drive and could fail permanently at any time.
Try reseating the hard drive and if you manage to get the laptop up and running, I would suggest you back up your data before the hard drive fails.
3answers
How to switch my bluetooth on my laptop dell vostro a860 and got windows vista.
easy.
#does your laptop have a bluetooth connection?
#if not you will need a dongle.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
