Posted on Jan 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba laptop A205-S4639 satellite
I discovered that my laptop has no sounds even if i open the settings. when i put also my headsets still no sound was coming. please help me.
Carlos L. Burgos
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Expert 620 Answers
  • Posted on Jan 05, 2008
Carlos L. Burgos
Expert
Level 2:
Prodigy:
Answers
620
Questions
Helped
218682
Points
723
Hello there
Use a headphone to the Headphone jack to see if sound comming in the port. and see if nothing is on mute on the mixer.
good luck
other than that, is a posible onboard sound problem, or BIOS is DIsable sound. check that
Anonymous
Level 3:
Master:
  • Master 619 Answers
  • Posted on Jan 04, 2008
Anonymous
Master
Level 3:
Master:
Answers
619
Questions
0
Helped
350743
Points
1019
Check the computer open media player an play music , adjust volume ,if no sound open control panel re install sound driver .
check setting mute must be off.
  • Anonymous Jan 04, 2008
    if you laptop having extention speaker try to connect speaker w/aplifier.
Toshiba satellite CD door will not open
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
1) ALL power removed. Remove the AC adapter (Charger), and Battery.
2) Turn the laptop over bottom side up, Battery Compartment facing AWAY from you, down on a table.
You may wish to lay a soft Static free cloth on the table, to prevent scratching the table, or laptop.
3) Take this cover off,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Remove the Ram Memory module/s. ('Stick')
Lay them/it carefully aside. Handle by the BODY. The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins at the bottom.
The Body is coated with a see-through protective plastic.
4) Remove this Philips head screw, and push the optical drive out,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-03.jpg
The top of the optical drive will have small Philips head screws, or Torx screws. They sell Torx screwdrivers real cheap,
http://en.wikipedia.org/wiki/Torx
Remove the screws, remove the cover, remove the disk.
Regards,
joecoolvette
[Sounds like you may need a replacement optical drive ]
Toshiba Satellite A205 unable to fully shut down
possible setting issue.
If you Go to,
start, control panel, power options, (classic view)
have a look in the power options there, set as needed. there is a few, check them all out.
use disc cleanup,defragmenter, delete temp internet files, in tools on menu bar , delete history,
update the Operating system at Microsoft.
update virus protection and run a full scan.
you should be good if no hardware problems.
Regards.
Finger print sensor not working with vista in toshiba M200
here is the link :
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2211892&rpn=PSMC4U&modelFilter=M205-SP3018&selCategory=3&selFamily=1073768667&selModel=2211892|PSMC4U
Satellite A200-ST2041, A200-ST2043, A200-ST2042, A205-S4617, A205-S4618, A205-S4639, A205-S4638, A205-S4537, A205-S4557, A205-S5816, A205-S5814, A205-S5813, A205-S5812, A205-S5811, A205-S5810, A205-S5809, A205-S5806, A205-S5805, A205-S5851, A205-S5847, A205-S5843, A205-S5841, A205-S5835, A205-S5831, A205-S5825, A205-S6810, A205-S5823, A205-S5804, A205-S5803, A205-S5801, A205-S5800, A205-S7468, A205-S7466, A205-S7464, A205-S7459, A205-S7458, A205-S7456, A205-S7443, A205-S7442, A205-S4797, A205-S4787, A205-S4777, A205-S4707, A205-S5863, A205-S5859, A205-S5855, A205-S5853, A205-S5852, A205-S6812, A205-S6808, A205-S5821, A205-S5819, A205-SP5822, A205-SP5821, A205-SP5820, A205-SP5818, A205-SP5817, A205-SP5816, A205-S5000, A205-S5866, A205-S5879, A205-S5878, A205-S5872, A205-S5871, A205-S5867, A205-S5880, A205-S5861, A205-S5833, A205-S5864, A205-S4629, A205-S4607, A205-S4597, A205-S4578, A205-S4587, A205-S4577, A205-S4567, A215-S4697, A215-SP5811, A215-SP5810, A215-S48171, A215-S4817, A215-S4807, A215-S4767, A215-S4757, A215-S4747, A215-S4717, A215-S4737, A215-S5839, A215-S5848, A215-S5837, A215-S5829, A215-S5828, A215-S5827, A215-S6820, A215-S6816, A215-S7472, M110-ST1161, M115-S3094, M115-S3104, M115-S3154, M115-S3144, M200-ST2001, M200-ST2002, M205-S3207, M205-S4804, M205-S4805, M205-S4806, M205-S7453, M205-S3217,
The toshiba site do not have drivers for XP users, only Vista...
I believe you laptop has a Realtek sound card. Try this site see if you can find what you need:
http://drivers.softpedia.com/dyn-search.php
Good luck. Let me know if you have any other questions.
Joe
I have an A205-S4639... Install XP and the sound card not install the correct driver... need help [email protected]
You can download any/all the Windows XP or Vista device drivers for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers.
Use this link :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
1helpful
Toshiba Satellite a205-s4577
http://www.irisvista.com/tech/ This is a site that I use for dissasembly and repairs. Hope it helps.
Web cam
Have a look at link below to download appropriate driver for your webcam.
http://www.nodevice.com/driver/category/PC_Camera.html
Downgrad from vista 2 xp
hi there
it's being quite a long time since i solved my problem, so don't remember the details.
but I remember to have downloaded the drivers from Toshiba's site, filtering with the exact notebook model and XP drivers.
hope you get lucky
Keep Blinking after download..anything
Run a virus check, get a free one from download.com, also check that the lid isn't faulty, if you move it slightly while working it could indicate whether there is faulty wiring or screen. Also check that your graphics drivers are up to date, eve if the laptop is a month old, the drivers may have since been updated and depending on what programmes you are running an update may be reqired. Good luck!
 Grubhead
Grubhead
SmartAviator
SmartAviator
