Question about MSI K8N Neo4-F Motherboard
Annoying digital audio output in windows vista
I have a 5.1 speaker setup at home and connected to my motherboard. i used the s/pdif output of the motherboard in windows xp and it worked well. it consistently received digital output even if no sound is playing.
when i installed vista, the receiver doesn't receive any signal from the digital output. and every time a sound comes in, it will come out through the speakers and at the end of the sound the receiver stops receiving signals again. it's so annoying because it's like manually turning the receiver on and off (where there's a large thump at the end of a sound) each time sound is received.
now, imagine hover buttons with sounds in websites. it gets really annoying. i can't locate the source of the problem.. please help me..
  • d33pdish Jan 05, 2008
    I've already done what you said, all my drivers have been updated to be compatible with Vista Ultimate but somehow I still can't get it to work.
    Thanks for trying anyway..
    Scholar:
  • 103 Answers
You probably just need to update the audio drivers for that MB to use with Vista.
And it just so happens that MSI's download page for that motherboard has only 1 updated driver for the Vista OS, and that driver update is Vista_Realtek_AC97.zip
Hope that helps, and if it does, please remember to rate this solution!
Posted on Jan 04, 2008
MS-7525 S/PDIF
Is it connected to an optical device? It won't dispaly as anything if it isn't connected.
Jan 25, 2013 | HP Pavilion Computers & Internet
Asus p5k64 ws SPDIF pinouts identified
Asus Support > P5K64 WS > Main Support page,
http://www.asus.com/Motherboards/Intel_Socket_775/P5K64_WS/
Click on the Downloads tab.
(Overview / Specifications / Download / etc )
Click on the blue Down Arrow to the right of the Select OS box.
Click on WinXP
Click on the + sign to the left of - Manual (9) at the bottom of the list.
Scroll the Inside blue scroll bar down, click on the blue - Global -
underneath the E3231 heading.
The port on the top that is to the Right, of the mouse SP/2 port;
is the Coaxial S/PDIF Out port.
Center hole is Positive, outside is Negative. (Ground)
Uses coaxial cable.
"This port connects an external audio output device via a Coaxial S/PDIF cable."
The port below it is the Optical S/PDIF Out port.
"This port connects an external audio output device via an Optical S/PDIF cable"
http://en.wikipedia.org/wiki/Spdif
Regards,
joecoolvette
Dec 29, 2012 | ASUS P5K64 WS Motherboard
Yamaha RX-V365 Receiver when I hook up my center channel it is not audible at all. The R and L speakers work fine when they were located in the FRONT A and FRONT B terminals, but when I moved everything to...
With what signal did you try? Maybe your signal source (DVD/TV or radio) didn't contain any sounds for the center channel.
Go to the Setup menu, Speaker setup / Manual setup and find there item called "Test tone". It will output a test tone to each speaker individually (you will see on LCD which speaker is being tested at each moment). If you will hear a sound from the center now, there is no issue and center is working fine, just your source didn't contain any sound for the center.
If it doesn't work, then either you have faulty cable, faulty speaker or faulty center output of the receiver.
- Try connecting the center speaker to different output of receiver (this will test if speaker is OK).
- Try connecting working LEFT speaker to left output with CENTER cable (this will test if cable is OK).
- Try connecting working LEFT speaker with working cable to the CENTER output (this will test the output of receiver if OK - but use the Test Tone from Setup).
May 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Would like help with hook up wiring
i can not find the sound driver of my notebook NT-R45 can you help me pls
Jun 03, 2009 | Sabrent SBT-USB51 External Sound System
Connecting BA735 digital 3.5mm plug with S/PDIF coax jack
The male mono plug (from the left small speaker) should be connected into the right speaker (small speaker with controls) . After plugging the multi pin cable from the control speaker to the sub-woofer you need to plug in a signal source from your computer (or any other digital signal) into the sub-woofer. This digital input looks like an ordinary RCA plug but carries many channels of audio. That connects to the enabled digital output of your computer. Some computers output digital through a 3.5mm jack others look just like an RCA phono jack. If you are lucky some BA735 sub-woofers have a second input that is a standard 3.5mm stereo jack and it will take analog audio from computer, DVD, MP3 player or the like. I have three sets of these speakers that I love because of their big volume considering such a small size.
Mar 29, 2009 | Boston Acoustics BA735 Computer Speakers
P5GC-MX/1333 internal audio speaker is not working
Open your case and find a cable that comes from your internal speaker and connect it to pins on motherboard marked pc speaker or int.speaker or speaker
Mar 21, 2009 | ASUS P5GC-MX/1333 Motherboard
How to use BA7500G on another computer
I have the same problem except i'm using a macbook and i'm trying to connect the speakers. My macbok accommodates optical digital audio output, but you have to buy a  a standard toslink cable with a toslink mini-plug adapter.  Since the speaker input is a digital coaxial (not fiber, optical) you have to buy a Digital Fiber Optical (Toslink) to Digital Coaxial (S/PDIF) Converter.  i haven't tried it, but i hope this solves our problem. i have the toslink now i just have to buy the converter. good luck to you.
Jan 29, 2009 | Boston Acoustics BA7500 Computer Speakers
Can i connect JVC SXXSW6000 home theatre to my pc...if so how?
You need a receiver. A surround sound receiver is a 5-channel amplifier with a line-level subwoofer out. These are available at electronics stores. Receivers usually have digital inputs like optical and coaxial that you can use with the S/PDIF output of your PC.
Nov 06, 2008 | JVC SXXSW6000 Speaker
GeForce4 MX 420 Video Card
First question: Are you sure you have a PCI card?
there are several points here:
Make sure you have the monitor connected to the correct output on your computer. (In this case to the output of the graphics card, not to your onboard output)
If you have a PCI card set bios to PCI
Setting it to AGP means the computer is looking for a graphics card in you AGP-slot on you motherboard.
I cannot help thinking, that you actually have a AGP card in a AGP slot and that you computer is not working on onboard, but on AGP. But you can check which graphics device is used, in display properties (right-click Desktop, Properties, Settings)
Please post some feedback
Apr 04, 2008 | VIA P4MA Pro Motherboard
MSI K8N Neo4-F Motherboard Logo
170 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
