Question about Dell E207WFP LCD Monitor
Horizontal lines Hi, my monitor is about 11 months old and has horizontal "blur" lines extending from the text etc.
  • jtf1972 Aug 22, 2008
    I get the same problem, with additional "ghosting" effects of some things that do not go away.
    Reseting the monitor seems to usually help briefly...
    I also frequently have horizontal lines about two inches apart that travel up the screen.
    Of course this started up on the refirbished monitor shortly after the warranty expired.
  • 3,940 Answers
Horizontal blur can be caused by both a bad monitor or a bad video card/Card Slot on the motherboard.
The easiest way to check this is to connect the monitor to a known good system. If the problem follows the monitor to the good system, the monitor is bad and will need replacement. If it works fine on another system the problem is the video card/slot
Posted on Jun 08, 2008
Dark, horizontal lines after text and dark images.
This implies that your monitor had gone bad. you need to take it to a computer repair shop.
Apr 10, 2010 | HP w1907 LCD Monitor
Horizontal lines appear in newly saved images
the only thing i can think of is the sensor being misconnected or kaput. are you viewing them on the camera screen or a pc? it could also be camara screen...
Jul 05, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Geforce 3 analog output: I have horizontal, blurred/faint lines scrolling from bottom to top of display, spaced 6 inches apart.
what kind of monitor? Have you replaced the cable? Try the pc on another monitor. You need to see if it's actually the monitor or the video card. replace the broken or defective part.
May 30, 2009 | Nvidia 64MB GeForce3 AGP Video Card with...
Vertical gray stripe on left edge, all pics and text gave a blur
any vertical or horizontal line (any color any size) showing stable on the screen that is the hardware damage at the LCD panel back board ( call panel driver board) . it repair complicate but easy to do change LCD panel (common parts). you need find a PC service dealer to do so.
Feb 07, 2009 | Dell E207WFP LCD Monitor
Monitor problem
Appreciate the "Ask Me".
I am assuming that you have more than just familiarity with electronic components and circuitry, the use of a DVM and a soldering iron. Further, that you have access to a service manual.
Width problem is basically insufficient horizontal deflection, then analysis would have to be in the horizontal section. Areas to initially focus on:
  1. 12V line and pin 29 of IC401;
  2. 110 V peak to peak at collector of Q403, if yes check Q 402 & 404 as well as T401;
  3. other components that affect the horizontal size are:
  • IC201
  • Q 405, 406, 407 & 408;
  • D409
  • L401
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 06, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Short, 3/8", horizontal blurs
I posted this answer on another "white streak" question, I suspect this is right:
This issue presents itself in different ways in this monitor, in the form of smeary video, or color changing from the left to right, or as you indicate, a smear following text. I know this as I own this monitor, and have repaired this myself. There are three 1 mf capacitors, surface mounted on the control board inside the monitor that fail. They are in the RGB input lines, and when they fail they cause distortion of the RGB signals, causing what you see. They are the three caps you will find in a row, spaced maybe 14mm on the board between the VGA connector and the processor chip. I would replace all three, observing polarity markings. You can get by just fine using old-style thru-hole caps, just form and clip the leads and solder 'em down on the surface-mount pads. I highly recommend proper soldering tools for this job though, especially for the removal of the old parts, they don't want to come off unless you can heat both pads at the same time.
Jan 15, 2008 | ViewSonic VA800 17.4" Flat Panel LCD...
LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Dec 13, 2007 | Samsung LN-S4051D 40 in. LCD Television
Toshiba 32d46 single horizontal line in center of tube
Hi. Check the frame output IC for dry solder joints.
Sep 15, 2007 | Televison & Video
Thin pale Horizontal line
I tried this and it has worked temporarily by banging the monitor not great but it did work, no tech knowledge if there is any other advise please email.
Hiyama Monitor Model: Vision Master 17 (8617E Chassis)
Horizontal dark line across screen shadowing text or other complex display data - giving appearance of 3D grooves or just dark lines on light background - temp fix (few minutes) by banging monitor or jiggling the video cable (thats what threw me for a while)
Removed tube base board and ran over disc capacitors and other solder joints whether they looked dry or not. No re-occurence in 2 weeks of daily use. Seems to have fixed it. (Be prepared for a lot of metalwork and screw removal when opening one of these up - I still havn't figured out how to get the PSU/main board out of one !)
(John)
Aug 20, 2007 | Gateway FPD1975 19" LCD Monitor
Dell E207WFP LCD Monitor Logo
283 people viewed this question
Alun Cox
