check to see if the belt is broke,there is a switch on the pulley that won't let the dryer start if the belt is broke it will just buzz when you push start button
Comments:
Nov 07, 2009
- try unpluging it for for 5 minutes and plug it back in,sometime it resets the board send model number next time
Nov 11, 2009
- check to see if door switch is broke,push on it and listen for a click ,if it doesn't click it's bad
the front panel on our Kenmore elete has no power to it. The panel is just dead. There is power...
(More)
the front panel on our Kenmore elete has no power to it. The panel is just dead. There is power going to the washer but it is just dead. Is there a fuse in the washer that can be changed or something I can look at.
my washer stops in the middle of cycle and it shows 2 F, won't spin or drain. it keeps beeping what...
(More)
my washer stops in the middle of cycle and it shows 2 F, won't spin or drain. it keeps beeping what should i do?
the dryer is beeping and the lights are going all over the place and the dryer is not drying the...
(More)
the dryer is beeping and the lights are going all over the place and the dryer is not drying the clothes. I f we unplug the dryer, and plug it back in it will beep again. It did run for a short time, but starting beeping again. The vent is cleaned after each load.
My kenmore 110.27062603 gets stuck when 27 minutes left. Sets there and hums. Sounds like the drain...
(More)
My kenmore 110.27062603 gets stuck when 27 minutes left. Sets there and hums. Sounds like the drain pump. I can tilt the washer forward and it will drain and continue.
