Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Washer Pump is working but the motor is not turning.Is there a reset button? I think the waser got over loaded.
  • happymarried Feb 12, 2008
    The motor is'nt turning what do u think it could b?
    Scholar:
  • 196 Answers
There is no reset button on this type of machine. The motor will not work if the lid switch is faulty. When the machine fills with water (small load) is there a humming or buzzing noise. This is important because if the motor pulley has broken then the motor running by itself will sound almost the same as the pump. Have you removed the front access panel to check ?
Posted on Jan 08, 2008
My screen waser moter not working
First, check the availability of water in the wiper tank. If its OK then check the condition of the rubber tube. Then replace the motor if needed.
Mar 07, 2014 | Maruti Cars & Trucks
Hi my washer will not drain or spin Please help
lid switch or pump 1st start washer is the washer agatating lift the lid if it stops you need to ck the water pump all wasers need to drain the water befor thay will drain
Jun 24, 2011 | Maytag Performa PAV2200
My lg frontloader will not drain. I read the comment, but how do I get to the impeler?
I just got through replacing this and found the service manual at http://www.appliancefactoryparts.com/content/pdfs/125459.pdf (it applies to several LG wasers, but this was a huge help to me to step by step get to the pump motor). Also, there are two identical motors (with impellers) on the WM2277HW, one pumps the dirty water out, the other recirculates the water back into the drum to help mix the "cycle water" with the appropriate liquid (after it is dispensed). Hope this helps
Sep 01, 2010 | LG WM-2277HW Front Load Washer
Kemore waser leaking
center front ,,pump is bad ,,if you need help changing,,post question
Dec 26, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
HE3 Washer just keeps beeping at me when I push the start button
Bad motor pump and it's a common problem kenmore elite front load washer so we need to left the washer from the front and get under the washer to get the motor pump replaced
Nov 05, 2008 | Kenmore Elite 45986 Front Load Washer
Washer stopped working
To help you with this problem I need you to do something. Place the machine in spin cycle and see if it will pump the water out. Also, lift the lid and look at the back. There should be a model/serial number plate. This information would help.
I do not believe the motor is at fault. I suspect a bad motor coupler. If the machine willpump the water out then I am Sure.
Dec 16, 2007 | Kenmore 24032\24036 Top Load Washer
DOES NOT DRAIN WATER
If motor runs or sounds like it is trying to run, you have a sock caught in the pump. If no noise at all you have a bad lid switch
Jun 07, 2007 | Kenmore 94812 Top Load Stacked Washer /...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
154 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
