Cars & Trucks Logo
Posted on Nov 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I get heat out of the vents on the floor but no where else? how do I get the heat back to the defrost?
Anonymous
Level 3:
Brigadier General:
  • Master 3,092 Answers
  • Posted on Nov 04, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
3092
Questions
Helped
1514012
Points
10827
MAKE SURE SWITCH IS GOOD ALSO CHECK FOR VACUM LEAK TO VACUM HOSE GOIING IN TO FIRE WALL.
Defrorstores stay on ,try to change to floor, ac, heat vent ,deforstores still on 1995 thunderbird lx blower motor works great.
Some cars use vacuum from the engine to open and close the doors that direct the air to different positions. It is possible that the vacuum line to the controls is cracked or disconnected.
1helpful
How to repair
i'd think that the vent adjuster knob/slider is not working correctly strip out the heater panel around the control knobs and check the vent direction is working properly either stiff operation so a little wd40 on the cable would probably do the trick or some thing causing the vent itself to not move
1helpful
Ac vents not working
There is a blend door acuator which moves when u change your settings. Its a electric motor. Down under dash, Will need a mech and a heating and cooling diagram to find where the motor is,
2000 Ford Taurus SEL ac/heat blows through floor and defrost vents only
There is no vacuum to the controls. Look for a vacuum hose that is no longer connected to the engine intake manifold and repair it.
14helpful
Heat wont blow through heater or defroster vents
common problem, check under dash by the gas pedal if control arms are muving went selecting from ac to heat cuz this it is the control for the vents to go from ac to heat and to defrost.
Heat only blows out of dash vents, will not blow out of defroster
vvacum leak. in back of your temp control unit there is a series of vaum lines attached together they might even be in different colors these lines go to the vent and they open and close them when you slide the lever over this piece needs to be replaced
1helpful
2answers
No dashboard heat output
The climate control was poorly designed on these cars.
There is only heat on the floor and defrost settings, due to the layout of the ductwork.
Top GMC Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a GMC Expert? Answer questions, earn points and help others
