I just fixed a PC today that came into my shop with this same problem.
Booted with windows CD and did a repair, fixed in 5 minutes
find a friend and get their CD.I just fixed a PC today that came into my shop with this same problem.
You can't post conmments that contain an email address.
The service is completely free and covers almost anything you can think of (from cars to computers, handyman, and even drones). click here to download the app (for users in the US for now) and get all the help you need. Good luck!
some system on your windows has corrupted, it caused by a virus or bad disk you need to restore your system to fix this issue if your laptop build in windows xp and you have a restore disk just follow these steps 1. turn on your notebook 2.quickly press ctr and f11 simultaneously 3. click restore when "Dell PC restore" message appears 4.click confirm (it means you will lost all data in drive which contains your old operation system) 5.wait and click finish when the process of restore finish if your laptop build in windows vista you can follow these steps 1. turn on your laptop 2. quickly press f8 3. when "Advance Boot Menu" message appears just click repair 4. select language and click next 5. log in and click ok 6. click dell factory restore and click next 7. click yes on the box "format hard drive and restore the system" 8. when the process finish click finish if you don't have a restore disk build in your laptop you need a windows cd installer to reinstall your os
"Windows could not start because the following file is missing or corrupt: <Windows root>\system32\hal.dll. Please re-install a copy of the above file."
"<Winnt_root>\System32\Hal.dll missing or corrupt: Please re-install a copy of the above file."
"Cannot find \Windows\System32\hal.dll"
"Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears.
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Please let me know you have any further questions or concerns.
Thanks.
first boot your computer with winxp recovery disk. then ewnter in recovery console then type in command prompt "chkdsk /r" then press "y" then it fix error on disk. then check.
Verify the boot.ini file is found on the computer by using a boot diskette or use your Windows CD to get to the MS-DOS "C:\>" prompt.
From this prompt edit the boot.ini, verify that it is pointing to the correct operating system, and that no anomalies are found within the file. Below is a listing of what to verify
If only one operating system is on the computer verify that the boot.ini only has one operating system listed. In some situations an alternate configuration line may be added for the same operating system, leaving the improper line.
Verify that the "default=" line as well as the operating system line are the same and that they are pointing to the correct operating system.
Verify that the computer has the hal.dll file
From the MS-DOS "C:\>" prompt quickly determine if your computer has the "hal.dll" file by typing "dir hal.dll /s" at the prompt. If the computer returns a "File not found" message, the hal.dll has been deleted.
To recover this file boot the Windows operating system CD and choose the option to "Restore", "Repair", or "Recover." This option will prompt you for the Windows installation to use, the administrators password and will allow you to restore the proper file. At the MS-DOS prompt type the below command.
expand C:\i386\hal.dl_ D:\windows\system32\
In the above example "D" would be the letter of your CD-ROM drive and "C" the letter of the drive your operating system is installed on. For example, your disc drive may be D: and your hard drive is likely C:.
Use the ERD disk and repair the installation. Choose to replace all files, and then replace only the Hal.dll and Ntoskrnl.exe files.
If you can start another installation of Windows NT on the same computer, you can expand the correct Hal.dll and Ntoskrnl.exe files from the Windows NT CD-ROM. To do so, follow these steps:
Boot to the working version of Windows NT.
Start a command prompt.
Change to the CD-ROM drive.
Change to the appropriate folder on the CD-ROM (for example, I386 for Intel-based computers).
Type expand hal.dl_ <systemroot>\system32 where <systemroot> is the path of the non-functioning Windows NT folder.
Type expand ntoskrnl.ex_ <systemroot>\system32.
Restart the computer into the other Windows NT installation.
Okay, the driver for the printer (hal.dll) needs to be reinstalled.
Do the following:
Press the windows key and R Type in command In the command prompt that comes up: Type in cd C:\Windows\System32 Type in taskkill /f /im "hal.dll" Type in del hal.dll Then restart your computer
What taskkill does is kill the printer application that is using the driver so you can delete it. After your system restarts, Windows will automatically reinstall the printer driver, and the problem will be fixed!
Do the following:
Okay, the driver for IE (hal.dll) needs to be reinstalled.
Do the following:
Type in command
Type in cd C:\Windows\System32\
Type in del hal.dll
What taskkill does is kill the IE application that is using the
automatically reinstall the IE driver, and the problem will be
fixed!
