Question about Kitchen Appliances - Others
Bread pan leaks
The bread pan is having problems with some leakage, where the drive assembly is located. Can this be fixed at a reasonable price? What is the cost of a replacement baking pan? Please help!
  • 4 more comments
  • Anonymous May 01, 2008
    The retaining ring on the bottom rusted and fell apart. The paddle came up and the water leaked in to the motor. Now it's dry and working but even after I replaced the ring and secured the paddle it is still leaking.
  • David33146 May 17, 2008
    The hole in the bottom of the pan where the drive shaft comes through
    is completely rusted and won't hold water. I would rather get a
    replacement pan instead of throwing the whole thing away but Kenmore
    doesn't offer that part. Help!
  • Anonymous Dec 22, 2008
    I had the same problem with a bread pan leak. The fix suggested worked perfectly. Many thanks.
  • Gregg Schickling Dec 26, 2008
    The shaft seal on my TR800 is badly worn and leaks (rubber coating is wearing off metal bushing). Replacement parts are no longer available from the manufacturer. It would be wrong to dispose of a perfectly good breadmaker due to a 10 cent part. Do you have any suggestions regarding how I can cobble a repair?
    Note that one other person on this string indicated a successful repair, but there is no mention of what they did.
  • Anonymous Mar 14, 2014
    leaking bread pan
  • Anonymous Mar 24, 2014
    Leak appears to be from around drive shaft in pan and of course renders machine useless. Is there anyway of remedying this? Alternatively is it possible to get a replacement? I can find nothing on the web.
  • 6 Answers
Dry the pan completely. Fill pan halfway with water - do not spill any water on the outside. Carefully lift up to view the bottom and see where it is leaking. If it is leaking around the central shaft, this solution will not work. If it is leaking out between the pan and the round drive assembly it is probably leaking near one of the rivets. Or it may be leaking elsewhere from a small crack elsewhere on the bottom (less likely). Mine had a hairline crack near the rounded ridge near one of the rivets. (It came from forcing the pan into the bread maker when the cross pins were not aligned properly. Turn paddle from underneath until it need not be forced.) I covered the crack area with a thin coating of J-B Weld. First, I roughed the area with an old dental tool and cleaned with acetone (Lowes hardware). I used a Q-tip with the end cut off to apply the mixed J-B Weld. J-B Weld is good up to 600 degrees F. Any high temp epoxy would work. I got J-B Weld at a local Advance auto store for about 4-5 dollars. I have made 3 loaves so far. No leak!. A very thin layer of crust sticks to the J-B Weld - not really a problem. Some Teflon paint should fix that.
Posted on Feb 16, 2008
My bread machine leaks the liquid out through the drive shaft. How can I fix this?
If the leak is not too bad and you are NOT using the delay timer. Put all the ingredients in flour etc. add the liquid last and just before pushing the start button pour the yeast in. You can do this until you locate a "pan assembly" for your machine or email me at breadmachineshelp.com for good used machines. I have a pan assembly for the K6725 if you are interested in it let me know.
Dec 24, 2012 | Regal Ware K6725 Kitchen Pro Bread Maker
The bread pan started to leak after after about the 50th loaf. How can I fix this?
If it's leaking from the bottom of the pan then the sealed bearing assembly is broken or defective. You will need a new bread pan. Sorry Hank
Mar 30, 2010 | Oster Kitchen Appliances - Others
Worn out bread pan
I had great success in finding what I wanted for my breadmaker at http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Nov 15, 2008 | Breadman TR4000 Ultimate Dream Bread Maker
Removable bread pan is leaking oil
Nov 10, 2008 | Kitchen Appliances - Others
Need a new bread pan
Check http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Nov 04, 2008 | Regal Ware K6725 Kitchen Pro Bread Maker
Need bread pan for Welbilt model ABM6000
Oct 24, 2008 | Welbilt ABM3500 Bread Maker
Seal in bread pan leaks
try http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Oct 12, 2008 | Regal Ware K6725 Kitchen Pro Bread Maker
Sanyo bread maker bread factory model
Aug 22, 2008 | Sanyo SBM-20 Bread Maker
SANYO breadmaker model 201
Probably a bad seal. Try http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Jul 18, 2008 | Sanyo SBM-20 Bread Maker
Kitchen Appliances - Others Logo
581 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
