Akai pt46dl10 rear projection tv
Hello, the problem that I am having with the akai pt46d10, on Dec 29/07 the projection bulb blew, made a pop noise no picture. pulled out bulb (broken filiment) replaced bulb jan 02/2008 had modify wiring differant bulb although same wattage and voltage. tv worked great. the following day tv would not turn back on, looked thru the grille at back could see illumination from bulb lasted approx 1 minute then went black, (turned off) now I am stumped do I try another bulb hoping that the first is defective? or are there any other checks, cooling fans do come on. tv is approx 21 months old thanks Doug
SOURCE: SAMSUNG PICTURE FREEZE (LOOKS BLACK&WHITE)
got mine working better unplugged the sound and wiggled the plastic coated wire above the large fan works but freezes maybe once in a day some days never have the sound running through the receiver (surround) I shut it off and it comes back on when it does freeze figure loose connection
Posted on Jan 06, 2008
scott201201
  • 170 Answers
SOURCE: Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
Posted on Apr 10, 2008
premtech
  • 934 Answers
SOURCE: PT5492S Akai PTV
That unit has a couple of various problems that are common. The first, I would check the 2d comb filter for ring cracks. If you see any resoldering them should restore the picture,
Bill
Posted on Nov 02, 2008
SOURCE: akai pt46dl10
Thanks Zeroice007.......but how do I get to run the 'operational software'?
Posted on Feb 26, 2009
  • 10 Answers
SOURCE: AKAI PT46DL10 Bulb replacement
order from http://www.replacementlightbulbs.com/ i did and works good now mine was type j
Posted on Apr 29, 2009
Akai PT46DL10 rear projection tv won't turn on
no lights, no warning, no noise. It is hooked up..unplugged and re-plugged, nothing.
Jul 29, 2010 | Akai Televison & Video
Need to find a bulb and cage for Akai pt46dl10
If your serial# has J P/N DR150E23
If it has a Z in serial# P/N L920-0017/P306
Mats Electronics 1-800-628-1118
And Go to E-Bay look under Electronics/type in Lamp number.
Feb 18, 2010 | Akai PT46DL10 46" HDTV-Ready Television
Tv popped and went out
Pops' are never a good thing to hear especially from rear screen sets. Could be that one of the three CRT's went/impolded. Could also be a Capacitor that blew also. Might be best to call a RV repair shop that works on Akai's - I think Magnavox builds Akai's but that's a guess.
Blessings,
A/V Media Guy
Nov 20, 2009 | Akai PT4298HD Rear Projection Television
Akai, PT46DL10 Has sound, no picture
make sure all componet cables are in the right color coded spots on the back or side of the tv and you are on the right componet if using a cable box make sure using componet / monster cables not all cable companies support hdmi if that is how you are trying to hook up make sure to check with them
May 14, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Code remote akai pt46dl10
had same problem tried all kinds of universal remotes but none were compatible look online and found only logitech Harmony® 550 Advanced Universal Remote is compatible with this model akai pt46dl10 bought one now works fine and was able to reset my lamp timer with it as i just replaced it paid $65 on craigslist for remote good luck
Apr 26, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Need to know how to change the lamp what is the procedure
theres a small square on back of tv you need a small torqz screwdriver to take off then bulb is inside theres a cage with bulb to reset lamp push menu on remote then enter 90918988
Oct 22, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Apr 10, 2008 | Akai PT5598HD 55" Rear Projection...
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
