Question about Compaq Presario R3000 Notebook
Compaq Presario V2000 How do I find or locate the reset on the mother boardrecently replaced
I recently replaced the fan in my laptop. Now I keep receiving this message when I start it up.Intel UNDlcopyright (C) 1997-2000 Intel Corporation
For Realtek RTL8139(X)/8130/810X PCI fast Ethernel Controler V2.13(020326) PXE-E61:Media test failture, check cable PXL-MOF: Exiting PXE ROM
someone replied that I needed to reset something on the mother board but I don't know how to identify the nother board. Does anyone have a diagram or something that will help me.
Thanks
sandra1946
My notebook displays "Media Test Failure", "Check Cable" PXE-M0F, PXE-E61, "Exiting PXE-ROM" I figured the hard drive was fried. I bought a new hard drive. When I tried to load Windows XP, it tells me there is no hard drive in the notebook. HELP!!!!!!!
  • acbyrd4u Jan 04, 2008
    This did not work for me
    My Presario R3000 notebook displays "Media Test Failure", "Check Cable" PXE-M0F, PXE-E61, "Exiting PXE-ROM" I figured the hard drive was fried. I bought a new hard drive. When I tried to load Windows XP, it tells me there is no hard drive in the notebook. I tried to run the HDD Self Test but I get "No IDE Devices" HELP!!!!!!!
    President:
  • 1,944 Answers
Firstly did you turn off network boot in the bios? Also, do you have a hard drive configuraton option in your bios? What is listed in your boot priorities (and in what order?)? Which exact hard drive did you buy? Did you configure the jumpers correctly on the drive (master/slave)? There is most probably no IDE cable on in your laptop...so check the IDE connector unit and see that it hasn't been detached from the motherboard. Also, check that the holes for the pins on the IDE connector are fine.
Posted on Jan 04, 2008
    Guru:
  • 1,894 Answers
SIMPLE.
YOUR IDE PORT IS HAVING SOME DEFECT. OR YOUR IDE CABLE IS HAVING SOME DEFECT I THINK.
CHANGE THE CABLE FIRST. IF THIS IS NOT WORKING. YOUR PORT IS ERROR FOR SURE
  • 1 more comment
  • dewan nafees ahmed Jan 04, 2008
    ELSE U DO ONE THING.
    BEFORE ACCEPTING WHAT I TOLD IN PREVIOUS SOLUTION CONFIRM IT.
    GO TO THE BIOS SET UP AND SEE IF YOUR HARD DISK IS SHOWING IN PRIMARY DRIVES SECTION.
    IF ITS NOT SHOWING MEANS WHAT I TOLD WAS TO BE RIGHT.
    IF AT ALL THE IDE PORT IS DETECTING ANY OTHER HARD DISK MEANS THE NEW HARD DISK THAT YOU HAVE REPLACED IS FAULTY. GO AND REPLACE IT FIRST.
    THEN SYSTEM WILL WORK FINE
    ya ya.. sorry.. IDE CONNECTOR only i mentioned as IDE CABLE.. in desktop cable is used right.. i told in same flow.. dont mind..
  • dewan nafees ahmed Jan 09, 2008
  • 556 Answers
This message is an attempt to boot from your network adapter (Realtek RTL8139)
Information from HP or concerning this error after insertion of a new hard drive and other conditions.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00488753&cc=us&lc=en&dlc=en&product=500508&dlc=en&lang=en
I would recommend starting with step 1 with the original hard drive in the machine in case your original hard drive was not fried.
When you get to step 3 it will explain how to install windows on a new hard drive when dealing with this error.
  • david Jan 04, 2008
    My apologies for using the V2000 in the title of your message instead of the R3000 in the category you assigned the message. I hope you can see it as a reasonable error.
    Here is the link refering the R3000 model with what appears to be completely identical content which will provide you no additional assistance.
    http://h10025.www1.hp.com/ewfrf/wc/docum...
    I hope the other experts here can assist you further.
  • 689 Answers
Hi
Error is related to detection problem of Hard drive. first possibility is Hard drive might have malfunction and needs to be replaced (even if its just purchased), Second possible reason is statical lockup on the board. Second possibility has instant solution but chance around 10-15 %. Solution is full power cycle and component discharge. Here is the easy steps. Disconnect AC adaptor (Power Cord). Release battery and take out from its bay. while nothing powering the computer press the power button and hold for 7 seconds. After that put the battery into its bay and connect the AC adaptor. Turn on the computer. If issue persist contact to manufacturer as you mention you have bought new Harddrive. Please post if any further questions you have.
Good Luck
    Genius:
  • 1,226 Answers
You can download the compact presario manual here: http://h10032.www1.hp.com/ctg/Manual/c00568473.pdf
All the manual found here: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&cc=us&dlc=en&product=500508&lang=en&
Maybe you can press "F2" to the enter the bios setting of mother board and select the optimized default setting and then press " F10" to save and exit.
  • Emelio Navaja
    Emelio Navaja Jan 04, 2008
    simultaneously press " F2" when starting the system .
  • Emelio Navaja
    Emelio Navaja Jan 06, 2008
    check all your connection. some portion of it not connected very well. or some other connection not fixed specifically on the hard drive.
How can i change the CMOS battery of my Laptop Compaq Presario V2000?
Here is the location of the appropriate Service Manual - you will have to partially disassemble your computer to reach the battery and replace it.
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
Sep 19, 2012 | HP Compaq Presario 2200 Notebook
Compaq Presario V2000 laptop stuck on compaq logo screen
when turning on the system go into the BIOS and reset back the seeting s to factory defaults and reboot the system .. If this fails then reseat the Hard drive may have come loose or ?
did you recently add new software ? drivers ? hardware?
Oct 14, 2009 | HP Compaq Presario V2000 Notebook
Compaq V2000 overheats at power-in plug.
Sounds like the power jack has a short and needs to be replaced.If it melted the ac adapter tip then its a ground problem in the power jack or where it connects to the mother board.
Aug 11, 2009 | Compaq Presario Notebook
My Compaq Presario v2000 laptop does not power up after pressing the power on switch. It all started whenever I hibernated it. But it worked after several attempts. Now it has become dead. Can you help?...
Generally this type of problem arises due to Battey. But in u r case it appears like a Mother Board Problem.So u better to visit nearer HP/compaq Service Station u can extende warranty for another year if ur previous extended warranty expired within 6 months...there is a provision in HP Customer Support.
Apart from this You can buy third party Mother boards compatible for V 2000 in other Laptop Acessories store
Jul 08, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 laptop wont boot
hi it seems that ur mother board has been damaged.. and immediately u should go for replacement....
thank u!!!
Apr 09, 2009 | HP Compaq Presario V2000 Notebook
Display blinking and turn in to white color with black lines
no its not a driver you have a video chip getting ready to fail.on the v2000 it intergrated in to the mother board. soon you will be joining many other compaq v2000 and m2000 owners in the search for a mother board compaq has updated part numbers it a whole differant board for these units due to having a common failure rate of the original mother boards.Compaq know there was a over heating of the video chip that leads to failure but has not offered any assistance to there customers. john@johnslaptops.com
Feb 17, 2009 | HP Compaq Presario V2000 Notebook
Mother board
Here's a link to the V2000 motherboard listings at Ebay. Many of these have worldwide shipping, so you shouldn't have any problems getting a good board for your machine.
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=+Compaq+Presario+V2000+motherboard&category0=
Jul 29, 2008 | HP Compaq Presario V2000 Notebook
Its due to some changes in your laptop! If you have jus replace the fan then there should not be any changes except fan! I think your BIOS or some other hardwares are changed Plz see to that from where you have replaced the FAN! Becoz chaning fan doesnt need any other hardware to be changed! If other parts are changed then plz install all the necessary drivers!
Dec 03, 2007 | HP Compaq Presario V2000 Notebook
Compaq Presario R3000 Notebook Logo
225 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
