How do I get my HP 5610 All-in-One Printer back online?
Also, the display window on the printer is saying "Cartridge Error: Refer to device documentation to troubleshoot". When I looked into the owner's manual, it says to press setup to run a test page but the printer will not allow me to do this. We have checked the cables. THANK YOU!!
Try reinstalling the cartridge. Also listen carefully to the cartridge assembly movement. If you hear any grinding type noises your cartridge is reaching the proper home position. This will cause a cartridge error. If there is any grinding noise you may be in for a long task of realigning your cartridge position to its proper spot. Make sure that the position of the assembly is dead center when you reinstall the cartridge. If it is not move it the center as a starting point. Keep at this moving the assembly in either direction until you no longer hear grinding as the assembly attempts to find its home position. Good luck! Be patient. It may also help to completely unplug the printer for 30 seconds between adjustment attempts.
Was this helpful?
Yes
No
Popular Solutions for HP Officejet 5610 All-In-One
my officejet 5610 will print documents and pictures from my computer but will not print from web...
(More)
my officejet 5610 will print documents and pictures from my computer but will not print from web pages, is there a solution?
installing officejet 5610. Donlt have disk for installation and list of copiers does not list 5610....
(More)
installing officejet 5610. Donlt have disk for installation and list of copiers does not list 5610. What model would be compatible?
