First try to open both doors and slid it threw the door. slide it threw like a c if you know what im talking about. i sold ge and westing house at the local goodyear tire store foe 19 + years. it worked for me.
Your have a good idea re the defrost timer. But there is also a thermostat that turns the compressor back on when the temp hits a certain point during the defrost cycle and defeat the normal cycle.. Check that out.
Before removing the door you need to release the lock on the oven door hinges. Door hinge locks are slide mechanisms or pins located on top of the hinges Once lock is released you will be able to pull out the door by opening it a bit, then lifting it up and pulling out.
Here parts and diagrams for your oven: MGR5755QDW.
Check condenser is cleaned. Replace relay and check compressor is working. If working keep your arm on condenser coil to feel warm. If not, no gas int he system. Call repairman to rectify. And also keep fridge temp setting between 36*F and 46*F and freezer temp between -14*F and 8*F. Thanks.
Usually, there are bolts/screws on the hinges. They may be covered with a plastic cap which will snap off. Start with the freezer door. While supporting the door, remove the screws from the hinge and lift to free the door. Now you should have access to the hinge supporting the refrigerator door. Same procedure for refrigerator door. Keep the screws in a safe place so you can reassemble the refrigerator when the kitchen floor is done.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
Unplug the unit or shut off the circuit breaker for 5 minutes.
Plug the unit back in or turn on the circuit breaker. Set the clock and gently
try moving the door lock lever (is so equipped) or opening the door. or Set the self-clean cycle again and only allow it to work for 15
minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try
moving the door lock lever (is so equipped) or opening the door. If these
procedures fail to correct the condition, the lock must usually be accessed and
moved manually to open the door. Some model
ovens require the oven door to be manually unlatched before the controls are
returned to the OFF position or else the door may not be able to be unlocked.
Check the owner's manual for proper operating procedures.
Check to make sure there is a nylon washer between the bottom of the doors and the hinge. Also, the hinge mounting screws generally can be loosened, the door shifted a bit, then re-tighten the screws to adjust the fit of the door.
in your user guide it explains procedure to remove the door, after emoving the door and layingit flast on conter /table ita amtter of removing sccrews holding on glass, and top trim to get to the screws that holdon hanlde, a little patience is all thats required not hard here
