Remove the top trim piece where the filter is. Disconnect the Gray flex hose from the vent terminal. Fire up the heater. If it fires you have either a blockage in the vent or a slow combustion blower. If it still gives you an error code, Inspect the combustion chamber for cob webs or debris. You can access the chamber by carefully pulling the flame rod and electrode out from the front port. Be careful with the fiber gasket. Blow some air in the chamber and vac out what you can. Polish the flame rod with a tooth brush and clean off terminals on electrode.
Was this helpful?
Yes
No
Popular Solutions for Rinnai RHFE-1004FA 38,400 BTU
I have a Rinnai Energysaver 1001ft it has the outlet at the back for the heater ducts. I, however...
(More)
I have a Rinnai Energysaver 1001ft it has the outlet at the back for the heater ducts. I, however would like to have the heated air to blow from the front vents. How do I achieve this? My email add. is nwidmer@bigpond.net.au thank you Nick Widmer
I would like our Rinnia 1001ft to blow heat out the front grill and not the rear duct how do I...
(More)
I would like our Rinnia 1001ft to blow heat out the front grill and not the rear duct how do I achieve this
rinnai energysaver 1000ft I havent used it before - we just bought this house with it instaled. when...
(More)
rinnai energysaver 1000ft I havent used it before - we just bought this house with it instaled. when I turn it on the fan goes for a minute or so, the ignition fires and the red light turns on, then the whole thing shuts down . any help?
