Question about HP DeskJet 3820 InkJet Printer
HP 3820 Deskjet Printer
When I try to print a page, an error message says that the printer cartridge carrier won't move because of a possible paper jam or other obstruction. I can't find any paper jam or obstruction after I lift the top lid. I can't find any paper jam or other obstruction by removing the back lid either. After closing the top lid, the printer spits out one piece of paper and then makes a clunking noise and then the green & yellow lights start flashing. I have unplugged the printer from its power source. I've uninstalled the printer software and then reinstalled the software. All to no avail. HELP!!
    Master:
  • 619 Answers
Unplug power and put in back the plug to outlet observe ,If same problem occured remove printer ink , Unplug the power check the loading tray let little bit incline printer so that visible inside tray loading what ever struck inside .remove if any thing that not parts of printer.
Posted on Jan 04, 2008
  • 233 Answers
1) take a flash light and inspect the paper path just to make sure there really is nothing there.
2) print a test page from the printer by pressing the big button ( I think) one of the buttons, can't remember I work on so many models
3) take out cart. turn off then on, install cart. and do step 2
what happens
I tried printing text including elaborate colorful artwork on the pages. Some of it printed but the text became increasingly smeared. Finally it would not print any more. Hours later I tried copying a...
2 possible causes: 1 - the ink has started to dry in the cartridges, it has become too thick for the heads to project on the paper correctly and in the end it has clogged the printing heads - replace the cartridges and run several deep cleaning cycles. 2 - hardware fault: either the data cable (the ribbon that connects the print head carrier to the mainboard) has been damaged and it will have to be replaced at a repair shop or the processor of the printer has just failed - this is terminal since it will be cheaper to buy a new one than to replace the mainboard. To make a pretty exact diagnose of the situation take out the cartridges and see if the printer recognizes the situation when you try to print something. If you get an error message then it's the data cable, if the printer is unresponsive then it's the processor - time for a new one.
Aug 23, 2011 | HP DeskJet 6540 InkJet Printer
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
Paper jam error message. Done evrything possible but still can't resolve.
Please try this solution.
Remove the USB cable into the printer and leave the printer on.
Remove all the cartridges.
Close the cartridge door and wait for the INSERT INK MESSAGE to appear.
Disconnect the power cable and from the power source supply.
Move the carriage using your hand from the original position to the other side of the printer and then move it back to original position. Wait for couple of minutes
Reconnect power cord and turn on the printer.
Return all the ink cartridges and close the door. Wait for the calibration process.
Print the test page to check if it working.
Reconnect the USB cable and try to print again.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Apr 20, 2011 | HP DeskJet F4280 All In One Printer InkJet
Even thought there is NO paper jam, I still get an error message:
Please try this solution :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Feb 19, 2009 | HP DeskJet F4280 All In One Printer InkJet
Printer Cradle does not remove to center of cradle rod
Bad cartridge carrier, probably uneconomical to get it fixed. However, try unplugging the power cord for 10 seconds. Good luck.
Jan 22, 2009 | HP DeskJet 3820 InkJet Printer
F380 deskjet - error - refuses to pront
I have this printer with the same problem , worked fine for 1 year, printed over 1600 pages total ( according to the built in HP program that records how many pages I printed and how many times I used the printer) then it stopped printing. The ink cartridges are new, the software is fine, and it says ink levels are good. It physically goes through the motions of printing, loads the paper, makes all the normal sounds it used to and pushes out the paper when it's done - but the page is blank. I did some surfing and read some info that some HP printers are pre-programmed to stop certain functions so you buy a new printer. I know that might sound crazy. How long have you had the printer and how many pages do you think you printed?
Nov 09, 2008 | HP DeskJet F380 All-In-One Printer
No PRINTOUT, only blank page/ no page received
Dear Teleios
'power button blinking without taking a paper to copy' usually means paper jam or no ink error.
First ensure you have no paper jam and you just replaced both ink cartridges.
If the printer still does not print, or does not print colors or black ink, then the ink must have dried up on printer head/nozzles.
You can try using clean nozzles option from hp printer software several times, and see if this fixes the problem. If it does not you will need to physically clean printer heads inside with solvent and cotton. To do this you need to disassemble part of the printer.
Having same work done in a service centre should cost around 50 euros.
HP DeskJet 3820 InkJet is not an expensive printer, if you cannot fix it with a clean head / nozzles from software you may also consider buying a new one for slightly more than the price of a cartridge change.
Regards
Mar 24, 2008 | HP DeskJet 3820 InkJet Printer
HP Deskjet 3820 states system error
try disconnecting from computer, and run the test page from the panel..then, reconnect to computer and see if it repeats..sounds like the operating system may have lost the printer drivers..
Mar 07, 2008 | HP DeskJet 3820 InkJet Printer
Deskjet 3845 not printing properly
it needs a proper service as the moving parts are not moving freely .. or maybe when installing the cartridge you have damagaed one of the sensors .. it can be one of both
Jun 25, 2007 | HP Deskjet 3845 InkJet Printer
Cartridges not moving
Sounds like a corrupt driver, uninstall your printer (Start> Printers and Faxes on right column), select your printer icon, right click>Delete. Disconnect your printer and re install drivers first, then reconnect printer when prompted. If still not performing correctly suspect printer head carrier fault.
Oct 25, 2006 | Apple HP DeskJet 3820 InkJet Printer
HP DeskJet 3820 InkJet Printer Logo
204 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
