Question about Brother MFC 210C All-In-One InkJet Printer
The parameters are incorrect and the printer won't print
  • 832 Answers
Could you please give some more details what is wrong with your mfc? What paprmeters do you mean? Which probs does the machine do?
Please post it as a new post!
Posted on Jan 04, 2008
6ya staff
SOURCE:
Incorrect parameters when scanning
all setting getting to default then try again
May 18, 2012 | HP Photosmart 4180 All-in-One Printer
What's a 016-799 error code mean?
016-799 Wrong combination of print parameters, like selecting to print on custom size paper and setting [Auto] for [Paper Source] on the printer driver and [Auto] for [Paper Size] in trays 1 to 4 on the control panel.
Check the print parameters.What we did is match the documents page size and paper type to the printers (A4) then we could print.
Oct 04, 2010 | Xerox WorkCentre 7328 Multifunction laser...
Zebra 105sl laebls always come out blank
Power on while holding the pause button for 5 seconds. This should print black bar across the width of the label. If this prints, then check the darkness parameter in your label format or driver. Also check to make sure your ribbon is feeding coated side out. There is a shiny side and a dull side to a ribbon. The dull side should be against the media. If it is leaving an image on the ribbon and nothing on the label the ribbon is either loaded incorrectly or not a zebra ribbon.
Oct 03, 2010 | Zebra 105SL Thermal Label Printer
Printer does not recive docket when it is sent from the servery, it's all jibberish! With numbers and letters just being printed out. Please help!
Most likely, you are using the printer's serial (rs-232) interface and your baud parameters on the printer and the computer are mis-matched. Print a test page by turning off the printer, holding the feed button down WHILE re-powering the printer. This will print all current parameters for the printer and it's interfaces. In the device manager, locate the icon for Ports (com LPT). Double click the icon and locate the com port your printer is connected to. Double click this com port to reveal the Properties. Under the port settings tab, match the port parameters to the ones on your test print. If that doesn't get it, you most likely are not using the serial port and have an incorrect driver loaded. Good Luck
Aug 18, 2010 | Posiflex PP7000 Printer
Zebra 105sl printer shows Error Code: ribbon out Printer Idle: 60-16-3z after we moved it from a different location. However, we've been printing fine w/o ribbon for many years.
so u used the direct thermal label that doesn't need a ribbon ? check the driver at Printer & Faxes on the PC, change the print method on the printing preference from thermal transfer to direct thermal
Jul 21, 2009 | Zebra Printer 140-751-00000
HP PSC All-In-One inkjet printer--incorrect parameters
RE CONFIGURE , REMOVE everything that has to do with the HP printer from your laptop , and RE INSTALL IT using the installation disk, hope this helps , AJ
May 18, 2009 | HP PSC 2355v All-In-One InkJet Printer
Service Call Error 0001001D
Hi poulin,
Click here to access your printer's manual
http://support.epson.ru/products/manuals/000909/spro798400rg_e.pdf
Page 327 on that manual will contain information on how to troubleshoot service errors. On page 115, it talks about adjusting parameters for better print quality.
Hope you may use the manual to troubleshoot your printing errors on your own.
Apr 09, 2009 | Epson Stylus Pro 9800 InkJet Printer
Zebra S4M Printer doesn't print
The fact that the Data message is displayed, means it is 'seeing' something. You may be losing the command character at the beginning that would cause the machine to ignore the rest of your code. If this is the first time you have attempted to use the serial port, you may have a setting incorrectly set. You need to match your Host exactly or the data may be framed incorrectly. The old standard was to send your data 8 bits, 1 stop-bit and no parity. Try Xon-Xoff with hardware handshaking too. I hope this helps.
Apr 04, 2009 | Zebra S4M Thermal Label Printer
My HP Photosmart C5180 All-in-one Printer - Scanner - Copier is not printing in the size i want it to. I have selected the default setting of 'fit to fill paper size' and i have selected what size paper i...
have you check the software parameters and you printer parameters?
I'll explain: when you launch a print usualy via file>print or ctrl+P you get a "software" menu and in that menu you have something like advanced parameters that leads you to your printer parameters. Maybe one of them is wrong.
If not check you file format, what softare do you use to print?
Jul 18, 2017 | Office Equipment & Supplies
Euro Symbol Printing
0128 is not a recognisable sysmbol Go to the Toshiba web site and the tech Support team- evidently there has been an error in the printed instruct as to the symbol number.
May 21, 2007 | Toshiba TEC BSX5 Thermal Label Printer
Brother MFC 210C All-In-One InkJet Printer Logo
99 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
