Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Insert disk i cant access the flash drive.. when i double click the drive it says that "please insert a disk into the drive". what seems to be the problem..thanks i need you assistance!
  • 5 more comments
  • crisyen Jan 10, 2008
    everytime i double click the drive it will display "please insert a disk" or "no disk found". It can detect the flash drive but i cannot open it.
  • Anonymous Jan 13, 2008
    Yes I have the same problem what should we do ? how do we fix it! I have important data inside it.
  • Anonymous Jan 30, 2008
    Same problem for me except on a mac. It flashes like it works but it won't show up anywhere. I've moved computers, usb areas. Still nothing. What should I do?
  • hojey_love Feb 01, 2008
    yes give me the solution
  • Anonymous Feb 05, 2008
    i have a kingston dti/4gb. when i enter the pen drive it says ' please enter a disk into the drive'
  • Anonymous Feb 06, 2008
  • Anonymous Feb 15, 2008
    when i click on driver it say incert disc in drive
Exact same problem for me, except on a mac. I've owned it for 6 months now, it's been working fine until now. When I plug it in it flashes (as if it works) but it won't sow up ANYWHERE. What should I do?
Posted on Jan 30, 2008
6ya staff
SOURCE:
Hi, my pen drive is not accessible l8ty, wen inserted in ne pc u can c the Removable Disk but wen double clicked on it it says " please insert a disk in Removable Disk ". please help
Try these first
First off try it in a different computer and if that can read it then you know for sure that the problem is with yours.
If it does not read on another computer chances are the drive is dead and whilst uncommon it does happen.
Also if "shell hardware detection" is turned OFF in W7 then it wont tell you when it is plugged in but you can still read from USB devices. You just have to browse the "removable" devices from windows explorer Try them all if more than one is listed
Feb 21, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
"insert a disk into drive"
right click my computer
manage
in right panel double click storage
double click disk management(Local)
right click on the pen drive shown and click format
Oct 03, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Sandisk Cruzer no longer prompting for password
I think the problem is corrosion on the contacts. Shut the computer off. Gently insert and remove the USB drive several times to try and clean the contacts. Turn the computer ON and when Windows has set up properly, insert the USB drive and see if you can read it. Many of the new drives and reader ports do not use gold contacts (too expensive) but use copper or aluminium which corrode easier an easiest.
Jun 10, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Pen drive insert disk problem.
I think there is a virus that has disabled your pen drive please follow these steps to try and remove that disability for the pen drive.
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Locate, and then click the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\UsbStor
4. In the right pane, double-click Start.
5. In the Value data box, type 3, click Hexadecimal (if it is not already selected), and then click OK.
6. Quit Registry Editor.
Hope you like my solution.
May 25, 2009 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Kingston Flash drive is NOT accessible (8GB)
my flash drive is not supporting my computer kingston
Mar 04, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
1)I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also )I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also
Feb 13, 2009 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
My DT100/4gb data traveller (kingston) pen drive is not working.
when i duble click on my pendrive icon it shows please insert a new disk. and it even doesnt open up
Oct 29, 2008 | Transcend (589307) Media
Not able to access the Jaz Disk
Iomega has quite a bit of customer help info: https://iomega-na-en.custhelp.com Click: Other Products Then Click: JAZ 2GB Then Click: Windows XP Then Click: More Answers... Then type in "search text" area: "insert a disk" Then Click: Search Then Click: "Please insert a disk into drive X" error message when inserting or trying to read an Iomega disk If that website's search engine doesn't help, you can also log into: http://www.iomegasupportforums.com and ask the tech support people there.
Mar 28, 2007 | Iomega Jaz 2GB External JAZ Drive
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
223 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Ekse
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
