Question about Video Game Consoles & Games
Xbox will not read any disc
Xbox green light will blink and than go solid and not do anything. Yesterday try to burn a cd in it than said cd was bad then stop working.
  • 34 Answers
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Mar 09, 2009
    President:
  • 4,402 Answers
Bad Cdrom/dvd
The laser going bad is a pretty common issue with the drives, since it's a Hitachi that spindle motor could be all gunked up with dirt as well and cause that issue also.
if ya have a Hitachi, if it's a Samsung it could just be the laser.
http://www.llamma.com/xbox/Repairs/xbox_dvd_repair.htm
Posted on Jan 22, 2008
Aux power led light is amber on dimension E521
I think your problem is your memory or video card.
Below are some steps that I recommend.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Below are links and info I found from Dell's Website based on your model.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/specs.htm
Controls and Lights Front of computer:
Power button - push button
Power light
green light - Blinking green in sleep state; solid green for power-on state.
amber light - Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see "Power Problems" in your Owner's Manual).
Diagnostic lights
four lights on the front panel (see Diagnostic Lights.)
Standby power light
AUX_PWR_LED on the system board
Hard-drive activity light
green light - When the computer is reading data from or writing data to the hard drive.
LAN indicator light
green light - Solid green indicates that a LAN (local area network) connection is established.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/adtshoot.htm#wp1056411
Jun 03, 2012 | Dell Dimension E521 (D10E16) PC Desktop
Console cannot read the disc
Well, considering the age of the disc, I would say laser burn. This happens sometimes with the old consoles.
Dec 07, 2011 | Microsoft Xbox 360 Console
Put in disk in 360. Play Playonline viewer, but screen goes black, and says cannot read disk, need to clean or restart. I did this several times and same result.
I had this problem recently. What happened was you closed the game without logging out of Playonline. The long shut down I call it. This corrupts the FFXI data on your HDD. And since FFXI does not appear in the memory you have to format your HDD and redownload. I can guarantee if you put the disc in your xbox with no HDD that it will read or even place it in an xbox with a HDD that has never had FFXI.
Dec 26, 2009 | Square Enix Final Fantasy XI for Xbox 360
My xbox 360 won't read my halo 3 legendary edition game disc
The disc is bad try returnig it or run it thrue a cd cleaner i use memorex from wal-mart it works very good
Sep 20, 2009 | Microsoft Xbox 360 Console
Power symbol on power button keeps blinking green and doesnt stop and doesnt open the tray or read discs
You might want to ask Xbox directly for this one.
Call them at (800)-469-9262
Email them here
Or use Ask Xbox
May 21, 2009 | Microsoft Xbox 360 Pro System Console
360 won't read update disc
Bad Cdrom/dvd
Dec 16, 2007 | Microsoft Xbox 360 Console
DVD ROM STOPPED WORKING & GREEN LIGHT KEEPS BLINKING EVEN W/O A DVD OR CD
clean the dvd player if that doesnt work it has to be replaced.
Nov 19, 2007 | Microsoft Xbox 360 Console
Crw8424s scsi
the drive is ready to give up, when it cant read dvds or cd's and unable to eject because it cannot read tracks and commands it's time to buy a new one, they are very cheap and easy to fit yourself.
Sep 26, 2007 | Yamaha CRW 8424 Burner
Xbox does not read discs.
Getting to the dashboard screen is a good thing but still cannot rule out a bad circuit board or power supply. All the symptoms point to a bad DVD drive but the opening/closing by itself do indicate a problem with the microprocessor. Can you turn the power on and off with the small button?? If not, would definitely suspect bad board.
Aug 16, 2006 | Microsoft Xbox Console
Video Game Consoles & Games Logo
111 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
