I have a Konica bizhub c351 with and error code of c0211. I took the back off and played with the black motor that lifts the tray. The tray moves freely and the motor seems to move freely. When I turn the machine on it does not go through any kind of check like it did before it just goes to the same screen. Is there a way to reset this to get it going again to test if there is still a problem
The extra side tray feed was way out of alignment. It must have been kicked or bumped and the motor was not lining up to the feed so the paper was not getting picked up. There are two metal anchors on either side of the tray, they were adjusted. The c351 had to be reset after the repair, like rebooting a computer.
I have Windows 7 and have downloaded the Konica Minolta C351 driver,
but it will not print. The...
(More)
but it will not print. The troubleshooter says it cannot be reached
through the network, but I can view the IP address online.
When I scan 4x6 images from the automatic feed on the top of my bizhub c350 and then open that file...
(More)
When I scan 4x6 images from the automatic feed on the top of my bizhub c350 and then open that file there is white area around the outside of the image. Is there a way to scan these images so only the image is saved in the file?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
