Question about Kenmore 62702 Microwave Oven
Kenmore microwave bulb issues
Lightbulbs burned out, when I replaced them they still don't work. I replaced the fuse, still no lights. I unplugged it first and everything. Any ideas?
  • Anonymous Mar 05, 2008
    Kenmore Over the Range Micro
    NO lights under the micro working even after the bulbs were replaced. The fan doesn't work either. I want to know what I need to replace to get these to work.....please
  • Kenmore Master
  • 9,176 Answers
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
6ya staff
SOURCE:
How to replace lightbulb
Is this a countertop microwave or an over-the-rang (OTR) microwave? If it's a countertop model, you need to completely remove the outer case to get to the lightbulb. If it's and OTR microwave, there usually is an access cover located behind the grill vent. You can remove that grille vent by removing the 2 to 4 screws above the grill vent. Then either slide the grill vent 1/4" to the left to remove it, or else (depending on the model), just pull out the top of the grill vent, followed by the bottom. Then you should be able to see the lightbulb access cover. Usually there is 1 screw that you have to remove. But unplug the microwave before you to any further! Now remove the screw, lift up and remove the cover, and you should be able to get to the light bulb.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 10, 2014 | Kenmore Microwave Ovens
How to replace light bulb in combination oven model acm1580ab
Cannot find your model number, please provide make and model.
Jul 23, 2008 | Amana Microwave Ovens
Magic Chef microwave MCO160UW stopped working after trying to change the lightbulb.
First thing to do is unplug it and take a pair of needle nose pliers and get the base of the old bulb out and replace it. Microwave ovens have a lot of things wired in 'series' which means that is one switch,bulb or any thing else in the circuit goes out then the circuit cannot complete it's path and will not let the other parts function. It is a safety feature that is built into them. As in many things I think they over do the safety features but they didn't ask me when they built it. LOL! Try replacing the bulb and let me know how it works.
Mar 15, 2014 | Microwave Ovens
Http://tinyurl.com/yzjozk
i think your bulb fused because you change it without unpluging and the current\
directly hit the filament.
you should buy new one and try it again and remenber that you shoul unplug it first.
Dec 28, 2011 | Kenmore 62702 Microwave Oven
When changing the lightbulb under the over the range microwave oven I heard a pop sound and now neither of the lights or the fan won't work but the microwave and the clock on it still works, it is just...
probably caused a short while replacing the bulb(s) and, causing damage to the circuit board. pull the board out and carefully check for burned foil traces; and rebridge with solder. it may or may not work. always unplug the microwave when replacing the range lamps.
Aug 06, 2011 | Hotpoint RVM1435 Microwave Oven
Spacemaker xl1800 - heats, but lights and carousel out
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
William E. Miller
[email protected]
http://www.microwavedisplay.com
Aug 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can't get the light bulb out from under the counter microwave
the clear rubber is from the factory to keep the bulb from turning you need to cut this before you can replace the bulb . thats why the first bulb broke . there is no trick to getting them out , see if there is a glue strip on the broken bulb that if you chip off it will then turn . just be carefull what ever you do . ge thinks there microwave will die before the lights burn out ! it screams of there trust in there products . good luck
Jan 09, 2009 | GE JVM1650 1000 Watts Microwave Oven
Kenmore 62702 Microwave Oven Logo
432 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
