Question about Maytag Atlantis MAV6000 Top Load Washer
BLACK TAR-LIKE DEPOSITS INSIDE WASHER BASKET
FOR THE PAST FEW WEEKS, I HAVE FOUND WHAT LOOKS LIKE SMALL PARTICLES OF BLACK CRAYON INSIDE THE WASHER BASKET AFTER WASHING A LOAD OF CLOTHING. THERE SHOULDN'T BE ANYTHING LIKE CRAYON IN THE MACHINE. COULD THIS BE COMING FROM A BELT OR GASKET OF SOME TYPE?
    Master:
  • 619 Answers
THE DRUM INCLINE BOTH PLASTIC AND MEATAL SCRATCHING FROM DRUM CAUSE LIKE A CRAYON /SMALL PARTICLES , THE SUPPORT SPRING BESIDE THE DRUM ARE DETACHED NEED TO INSTALL SPRING / AVAILABLE IN APPLIANCES CENTER.
Posted on Jan 09, 2008
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: DEPOSITS IN BASKET OF WASHER
Outer Tub bearing grease???
Posted on Jan 04, 2008
Our tumble action front-loader washer just recently started leaving black marks in the pattern of the holes on the inside of the washer drum- We ran it twice without anything in the washer, and it still...
Thanks for stopping by:
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some de-greaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa!!
Aug 03, 2011 | Frigidaire 14 Cycle Tumble Action Washer
Small brown particles are found in filter and also what appeaars to be small grease stains on clothing what could be the problem?
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
if it's appearing on whites mainly (hot cycle)...
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Feb 07, 2011 | LG WFT1071TP Top Load Washer
I'm getting small orange spots/stains on my clothing after washing them in my Maytag washing machine. it is a 2010 machine too. Any thoughts as to what could be causing the stains?
Unless there is a child's crayon or something similar causing it, then suspect that the agitator shaft seal, or the drum seal is leaking oil into the drum. Hopefully, there is still warranty on the machine. Good luck!
Jan 10, 2011 | Maytag Centennial MTW5800TW Top Load...
Kenmore Elite coffee maker Model # 100.9101670A Is this model on a recall? How can I get a manual for it? And what is the filter reset button?
I have a manual with mine and as far as "recall" goes on this model, I've not found anything recalling this particular model...<br /> <br /> The most important thing in the manual, that I have found, is how to clean and change the filter. If all else fails unplug the pot for 10-15 seconds; replug it...this resets it...(if it ever acts up, do this; it helps)<br /> <br /> The filter reset button: Your coffeepot should flash a small message stating: "change filter and clean" To do this you first, turn off the pot, remove filter~(the filter is in a long thin black plastic thing and the filter cover simply snaps and pulls apart to expose the charcoil filter; Remove the Filter, then fill the coffee pot with 7 cups of vinegar plus 7 cups cold water; Place a paper type regular coffee filter in the brew basket, or a thin paper towel works well too~(This traps and holds particles that get trapped inside the pot)<br /> <br /> Before brewing; PLEASE NOTE, brew the first pot of vinegar/water mixture only HALF WAY then TURN OFF and let it sit for a good 15 minutes to soften any deposits...<br /> Turn the pot BACK ON and brew the remaining solution. When brew stops turn OFF coffee pot, empty the solution, and discard the paper filter...<br /> <br /> Refill reservoir with cold water and turn ON; you may want to dump this and refill with more cold water to ensure the vinegar taste/smell is gone...<br /> <br /> Now, wash the brew basket and the glass pot...Open the black skiny Water Filter and replace with a new charcoil filter...Put Filter back in pot...fill brew basket with coffee and brew some mighty fine tasting coffee!!! Hope this helps....Good Luck
Jun 29, 2010 | Coffee Makers & Espresso Machines
Calcium like deposits on plastic and glassware after cyc
Check the quality of water used in the machine. If water has hardness this may happen. Use water softener attached on line to the dish washer.
May 19, 2010 | Magic Chef 24 in. DU2000 Built-in...
Kenmore 90 does not spin (sounds like working & coupler is good)
If the coupler is ok then the next thing to check is the brake/ basket drive cam driver, the ear breaks off on em and won't release the brake. You must remove the agitator and drop the tranny to check itffbcc2d.jpg
Nothing is difficult about repairing the washer. I have repair photos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 13, 2010 | Washing Machines
Kenmore series 80 washer off balance
Go to www.applienceparts.com and ask them for assistance, it is a free service.
Mar 13, 2017 | Kenmore Washing Machines
Tar clothing
I would think you would need to presoak the tar stained clothes in a bucket of hot & Stong detergent water. If you use that stong a detergent in the washer you run the risk of damaging the seals. Either do that or use someone elses washer and drier. Then Run like He..!
Dec 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Black stuff in the bottom of the dishwasher
That black or gray stuff you're talking about is actually a combination of old food particles and soap deposits. The stuff builds up in the corners of the lower front areas of the tub and right under the inside of the door where it closes over the tub front. These areas can develop "scungy" deposits because these are areas that the dishwasher doesn't always clean and/or water remains pooled. A little routine cleaning about once a week around the bottom lip of the door and the door gasket with a damp sponge will prevent this build up. Hope this helps you.
May 11, 2007 | Whirlpool 24 in. DU920PW Built-In...
Maytag Atlantis MAV6000 Top Load Washer Logo
425 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
