Question about Dell Latitude D600 Notebook
Help on turning on computer
Hello, I attempt to turn on my computer and it does as follows: I press the on button, it acts like it's going to turn on and then it suddenly shuts down. What's the problem?
    Novelist:
    Scholar:
  • 136 Answers
Its hard to answer based on the available information. Basically it could be a number of things.
ie. the RAM is faulty, the first thing it reads from the OS tells it to shutdown due to some malicious software etc. etc...
Can you try to boot to the bios? If you can do the diagnostics to see if there are any hardware problems.
Also, you may want to see if you can put in a bootable disk to see if it works. I suggest you use the recovery disk that came with the laptop.
good luck.
smeags.
Posted on Jan 04, 2008
How can i reset my emachines e525 laptop to factory settings as i have tried and i cannot find out how, i also forgot to create a backup disk so i can not use one of them.
Have you try to press the F11 button ?
Turn off the computer,press the "Power" button. Wait for the eMachine's computer to reach the screen that reads "Press F11 to start recovery." Once this screen appears, press the F11 key on the keyboard multiple times to make sure that it registers. If the recovery screen does not come up, you will need to turn the computer off and back on again and attempt to press the F11 button again when the prompt appears.
After doing that is only necessary to follow the steps.
Jul 11, 2011 | Computers & Internet
Canon MP560 Gets error code 5100
Hello and Welcome
Error 5100 means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
  1. Turn off printer
  2. Remove both the cartridges from the printer
  3. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  4. Return the cartridges
  5. Turn on the printer.
Error will be removed
If the problem exist then then go to Canon authorized service facility for repair. You can also get support by Canon by phone, at 1-800-OK-CANON (1-800-652-2666)
Further assistance i am here to help
Please click on Four thumbs which are given below to this solution "if it is helpful"
THANKS & Keep Using Fixya
Mar 13, 2011 | Canon MP560 All-In-One InkJet Printer
What is the code for a One for All urc-7710 remote control for an ACER tv?
I found the manual online for the URC-7710, but i do not see a code for an Acer TV.
Try a code search by following these steps:
1. Turn on TV.
2. Hold down the Magic button, the red light will blink once then twice, release the Magic button.
3. Press 991, the red light will blink twice.
4. Press power button once.
5. Aim remote at TV and press the Channel Up button repeatedly (up to 150 times) until TV turns off. Note: if you skipped the code that turned the TV off you can go back by pressing the Channel Down button once.
6. Press the Magic button to store the code for your TV set.
Well, I hope this will help.
Cheers!
Jun 18, 2010 | Televison & Video
How do i get the ''outdoor'' feature turned on. I have a nodia 2320 and I had it set before but now I cannot find the opetion to turn it on.
hi, are you referring to outdoor feature on your profile? if yes, click on settings or profile on your phone, then select OUTDOOR..
Jun 07, 2010 | Nokia 2320 Cell Phone
How to go in safe mode?
to go into safe mode, turn on your computer and constantly press F8 immediately. You will press the F8 button at the first black screen, that is, when your computer displays its log.
While pressing the F8, a windows option will be the next screen to appear, amongst the windows option, you will see safe mode there, use your keyboard arrow key to scroll to safe mode and press enter.
By now,your computer should be loading on safe mode.
Good luck.
May 18, 2010 | IBM ThinkPad R51 Notebook
Turns On but not past the loading screen
Hello :
I recommend you to reset your RoadMate .
To reset your RoadMate please follow these steps :
1: Locate the button marked "Reset" on the left, right or bottom of the unit.
2: Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
3:If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
NOTE : Please don't attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
This solution should help with your problem . If that didn't help , then I recommend you call Magellan service for help .
PLEASE DON'T FORGET TO RATE !
Apr 16, 2010 | Magellan RoadMate 1340 GPS Receiver
Display for radio stuck in '7 SAFE' mode
This sounds like a Phillips Car Stereo:
To get the code in:
1. Turn the stereo off.
2. Turn off the ignition
3. Turn the ignition back on (dash warning lights on)
4. Hold and keep down the AS button on the stereo.
5. Turn the stereo on.
6. Release the AS button after 4 dashes appear on the display
7. Now enter code (if code = 7009. Press preset button 1 seven times, button
2 once
3 once
4 nine times
If you go past you can go round again by pressing the
preset button repeatedly
8. Once all 4 numbers are correct hold down AS again until you hear a beep (2 - 5 seconds)
9. The stereo after beeping will scan to program channels
You have 10 attempts to get the code in. However some models will not give you the number of attempts remaining!
Time delays work as follows:
Attempt 1. 10 seconds
Attemp 2. 30 seconds.
Attempt 3. 10 minutes.
Attempt 4. 20 minutes
Attempt 5. 40 minutes
Attempt 6. 80 minutes
Attempt 7 160 minutes
Attempt 8 320 minutes
Attempt 9. 640 minutes (yes that is 10 hours 40 minutes!!)
Vitally important thing to remember, the countdown timer works only when the radio is switched on. ANY interruption in the power will reset the timer!
So, be prepared for a VERY long wait to be able to enter the code!
Oh, and if it has reached 10 attempts, then it needs a dealer unlock.
May 09, 2009 | Car Audio & Video
SVA 2400 Monitor Problems
hello
1 debronche the internet cable then press off and see if the problem if it is not
2 search in the system
3, you can have a technical problem in your TV
if you guarantee
Contact the store business was purchased at the
Jan 21, 2009 | SVA-USA VR30 30 in. HD-Ready LCD...
Dell Latitude D600 Notebook Logo
16 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
