Question about Philips 50P8341 50" Rear Projection Television
Blue screen with sound but nothing else!
I was given a philips projection tv model # 50P8341. When you turn it on you get a blue screen and sound but nothing else. I tried adjusting the color but it just changed the color of the screen. I hit the menu button but nothing changes. When you turn the tv off I get a brief view of a picture. Is there anything I could do or do I have to take it in for repairs?
thanks in advance
I, too, acquired a Phillips without a manual and was experiencing a similar problem. My model is PTV 916, but if your TV has a "source select" button, say a prayer and press the button. From that point, I don't know what else I did, but I do get TV programs now.
Posted on Jul 01, 2008
6ya staff
SOURCE:
Well i made the mistake of changing out my coolant in my crts lastnight in my Philips 50P8341 50 in. Rear Projection. i changed them fairly easily and even did my red just in case but my problem is that at...
Coolant is highly corrosive and will destroy any component that it touches. So the components will need to be desoldered and removed then tested and reinstalled. Also turning the screen adjustments too low will prevent the CRTs from turning on.
Sep 19, 2010 | Philips 50P8341 50" Rear Projection...
Touched a button on remote now no picture or sound Help
do my philips tv has a reste botton model number is 50p8341
May 14, 2010 | Philips 50P8341 50" Rear Projection...
My Philips model 50p8341a 50" rear projection tv turns on, has sound but has no picture. Any ideas? Heard something about a convergence chip? Please advise.
you need ssb board is bad and you can,t git that part you can send to pts to have it rebuld. yes the stk 392-120 can drag the pix down but if you open it up you see a fouc blook go to the screen red or green or blue
turn it up just a litte the pix will come back. this is a know fact about this with this set i see a lot in my days of sevice ,at quaker tv
Dec 07, 2009 | Philips 50P8341 50" Rear Projection...
Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Oct 24, 2009 | Philips 50P8341 50" Rear Projection...
The on and off switch will shut the TV off after
my philips rear projection tv shut down within 1 minute when on rolling the letter av from up to down and curved uo and down also have red lines in screen
Sep 01, 2009 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 50 in. Rear Projection Television
Sounds like the blue convergence IC s bad. They are relatively easy to replace if you can solder they cost around 10.00 each and you should change both the red and the blue.
Feb 09, 2008 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 50 in. Rear Projection Television most of the color is red
Usually if you remove the speaker grill in front there is a convergence panel that can be carefully removed. If you look inside you should see a small rectangular block with six controls. They are labelled focus and screen, and red, blue and green. Adjust only the screen controls very carefully and slowly. I would recommend reducing the red slightly brfore raising the green and then blue until the picture looks acceptable. Be sure to center the on screen controls before starting.
Nov 18, 2007 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
81 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
