Maytag PYE2300AY Electric Dryer
Problem for Maytag PYE2300AY Electric Dryer
Noisy dryer.(belt)
By cynthia_dale on Nov 03, 2009
noisy dryer.(belt)
Solution #1
posted on Nov 03, 2009
Not Rated)
hunter19_46m
Rank: Guru  Maytag Washers & Dryers  Expert
Rating: 91%, 202 votes
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Was this helpful?
Yes
No
Popular Solutions for Maytag PYE2300AY Electric
Questions and Unsolved Problems for Maytag PYE2300AY Electric
Do you recommend Maytag PYE2300AY Electric Dryer?
Answer
Answer
my dryer won't turn on, when I push the start button I do hear the timer ticking sound.
Answer
wires for the maytag dryer are black, yellow, blue and white. We need to swap the cord for a 4 prong... (More)
Answer
the drum to my maytag dryer will not tur. i think the belt is broken
Answer
i received a free dryer, a maytag atlantis model# mde6400ayw. Upon trying to hook up the cords I... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryers Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
