Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Problem for Honeywell Electronic Programmable Heat/Cool Thermostat -...
What is the recomented settings for high and low
By wmtao on Nov 03, 2009
what is the recomented settings for high and low limit control for the
oil-fired water boiler model# LD-30PT. Honeywell aquastat L8124A
Best Solution
posted on Nov 03, 2009
Very Helpful)
Therinnaiguy
Rank: Guru  Honeywell Air Conditioners  Expert
Rating: 87%, 472 votes
180 with a differential of 15 or 20. So 180 high and 160-165 on low.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thanks " - wmtao
Popular Solutions for Honeywell Electronic
Questions and Unsolved Problems for Honeywell Electronic
Do you recommend Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater?
Answer
Answer
Is there an ''embedded'' program in the RTH6400D thermostat? I have set the ''wake, leave, return,... (More)
Answer
rheem oil furnace model robd 067 lbea blower never shuts off. the burner lights the blower starts... (More)
Answer
The home I just moved into has a ritetemp programmable system without instructions or model number... (More)
Answer
if the batteries are dead or weak will the thermostate not tell the furnace to come on
Describe your Heaters problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heater Experts
Top Heater Repairmen
in Newport, KY
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
