Question about Brother HL-2040 Laser Printer
Paper LED Blinking
The paper led is blinking on my printer. I checked for paper jams. I have none. In fact, I went through the trouble-shooting list on the following Brother website: http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000001324&Sympt=The+Paper+LED+is+flashing.++How+can+I+clear+this+error%3f&Model=3&ProductGroup=1&Keyword=feed%20roller&ProductID=HL2040
  • 1 more comment
  • Anonymous Jan 04, 2008
    On occasion, the machine will print the odd page, but normally, when one attempts to print a document, the rollers will revolve, no paper will come out and the paper light will come on. A friend, who knows a great deal about computers, tipped it on its left side, and it then worked for a few minutes. Now it is upright again, and doing the same thing.
  • wildwest949 Apr 05, 2008
    Brother laser printer HL-2030. Paper led red light continues to blink after paper jam. Pulled out jam and filled paper tray. Paper red light continues to blink. Normal Brother trouble shooting pages unavailable. Printer is about 3 months old and have only printed about 30 pages.
  • Anonymous Mar 29, 2014
    my brother DCP-J`125 tells no paper fed. Have done everything possible and still says no paper fed. Have not had this trouble before.
  • Brother Master
  • 1,113 Answers
Did you see http://www.fixya.com/support/r310860-lights_indicate
The Paper LED is flashing.
Paper LED Blinking - papereroor2.gif Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, click here.
Clean drum unit:
The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Posted on Jan 04, 2008
  • Soulvisitor
    Soulvisitor Jan 05, 2008
    Paper feed roller dirty or worn. clean or have replaced
6ya staff
SOURCE:
Brother HL 20 printer paper jam light keeps blinking after jam removed
Please check paper sensor may e damage, need to relpace it on prior basis
Mar 30, 2013 | Brother HL-2040 Laser Printer
Continue to receive E error message
Check control panel lights, if cartridge led's are blinking replace particular cartridge, if paper led's are blinking check any paper jam inside, if no paper found clean paper sensor.
Nov 24, 2011 | HP PSC 1315 All-In-One InkJet Printer
Show e on copies and check ink cartridge light is blinking with new ink cartridge
With "E" ,check cartridge LED which is blinking mono or color replace it, or else check paper LED if its blinking check for the paper jams..
Sep 27, 2011 | HP PSC 1210 All-In-One InkJet Printer
My HP Deskjet 1120Cxi fails to print normal document and test printing. My computer operating system is window XP
Power on the machine, check front panel 'cartridge led' blinking? replace the cartridges,if 'paper led blinking' indicates paper jam check for paper jam.If printer comes in ready mode check in system drivers its is ready mode?.. if no check parallel cable if its good replace formatter..
Sep 06, 2011 | HP Deskjet 1120c InkJet Printer
Indicator is not steady it is blinking.it is not responding to print commands.
Hi
If printer Leb is blinking then you have error in printer check the mention below note.
1) Check the printer door, all door close the properly
2) Check the paper Jam, remove the jam paper.
3) Check the cartridge level, change the cartridge.
Cheer
Jul 19, 2011 | OKI C7350hdn Led Printer
Ready and alarm lights keep blinking. will not print
Service manual: ready and alarm blinking :
Paper Jam
Clear the paper jam and press the panel button if the printer
does not automatically resume printing.
Misfeed:
Re-install the paper and press the panel button.
Clear the jammed paper inside the printer. Press the panel button
if the printer does not automatically resume printing.
check the sensors:
1) Turn off the printer power switch, open the front cover, and remove the drum unit.
2) Turn on the printer while pressing the control panel button. The Drum LED comes ON.
3) Lightly press the panel button again.
Alarm LED is ON = Front registration sensor is turned ON.
4) Press and release the panel button again.
Drum LED is ON = Paper eject sensor is turned ON.
If sensors are On, paper is being detected, Off- no paper
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 21, 2011 | Brother HL 1240 Printer
My Brother HL-2140 Went out in a storm. All three lights just keep blinking no matter what I do. Held down on the blue light button a number of time, restarted computer, turned off printer, reloaded ink...
You can find the usre's manual here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hl2140_all&dlid=&flang=English&type2=-1
1) If the LARGE BLUE BUTTON is blinking:
Data remaining in memory
There is remaining print data in the printer memory. If the Ready LED is blinking for
a long time and nothing has printed, press the Go button to print the remaining data
in the memory.
2) If the TONER LED is blinking:
Toner low
Indicates that the toner cartridge is nearly empty. Buy a new toner cartridge and have
it ready for when Toner life end is indicated.
The Toner LED will turn on for 2 seconds and off for 3 seconds.
3) If the DRUM LED is blinking:
Drum life end soon
The drum unit is near the end of its life. We recommend that you get a new drum unit
to replace the current one. See Replacing the drum unit on page 69.
The Drum LED will turn on for 2 seconds and off for 3 seconds.
4) If the RED ERROR LED is blinking:
Front cover is open
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
Memory full
Print overrun
Mar 26, 2010 | Brother HL 2140 Laser Printer
The amber lights are blinking next to the printer icons and exclamation points on top of the printer. How do i get that to stop so my print job can go through?
There 3 light on the printer that able to indicate to user when problem occur.
1st button light blink rapidly = the printer may be out of paper, so load more paper and press the 1st button itself to continue. Or may be paper jam is occur, so clear the paper jam and press the 1st button light itself to continue.
If 1st button light blink slowly = mean the cartridge carriers are stuck, so raise the scanner unit and remove any object blocking the path of the cartridge carrier, make sure the cartridge are closed and installed properly, then lift the scanner unit, gently push the scanner support towards the cartridge carriers, and carefully lower the scanner unit until it is completely closed. After that press the 1st button itself to continue.
If 2nd LED light blinking = the color cartridge need to be replaced soon.
If 2nd LED light is ON = the color cartridge need to be replaced immediately.
If 3rd LED light blinking = the black cartridge need to be replaced soon.
If 3rd LED light is ON = the black cartridge need to be replaced immediately.
YBC (/\)
Aug 06, 2009 | Lexmark X2500 All-In-One Printer
Paper LED blinking
Try feeding using bypass, probally worn/dirty/broke paper cassette paper feed roller having trouble feeding the paper in.
Sep 30, 2007 | HP LaserJet 4L Printer
Brother HL-2040 Laser Printer Logo
392 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
