Canon PIXMA  MP460 All-In-One InkJet Printer
Problem for Canon PIXMA MP460 All-In-One InkJet Printer
I m having problems installing the ink cartridges
By scolson42 on Nov 03, 2009
I m having problems installing the ink cartridges and sggestions?
Solution #1
posted on Nov 03, 2009
Not Rated)
satchi2k2
Rank: Wiz  Canon Computer Hardware  Expert
Rating: 84%, 430 votes
Installing ink cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover).The ink cartridge holder moves to the replacement position.
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
  2. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  3. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  4. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  5. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  6. Fold the scanning unit support and close the scanning unit (printer cover).
  7. Wait until the preparatory operation is complete; it takes about one to two minutes.
Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
  4. Fold the scanning unit support and close the scanning unit (printer cover).
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA MP460 All-In-One
Questions and Unsolved Problems for Canon PIXMA MP460 All-In-One
Do you recommend Canon PIXMA MP460 All-In-One InkJet Printer?
Answer
Answer
Got an error message saying paper jam. Removed the offending sheet of paper which came out of... (More)
Answer
printer display says paper jam and there is no paper jam
Answer
I have a paper jam error showing, but no paper jam in printer. What can I do?
Answer
black lines are running through the printed pictures. i have tried all cleanings and it still has... (More)
Answer
shows paper jam on LCD. I can send a print to it, turn it off and then back on. @ sheets of paper... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PIXMA MP460 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
