Your fan speeds up and slows down in response to temperature inside the computer. More so the CPU.
It may even shut down randomly with overheating.
I would suggest getting a can of compressed air made for computers
take it outside, take of the side and blow all the gunk out of there, Really go to town around the fan (you might want to wear eye protection) While you are in there just check that the CPU cooler itself is not loose
If it is it will have to be re-seated.
If it needs re-seating don't just take it off and put it back on as that might make things worse with your temperature problem they have to be cleaned and new thermal grease put on ($2-5)
DON'T remove the CPU just the fan/cooler assembly.
You must clean both the surfaces without scraping anything off. Use isopropynol alcohol and cotton bud sticks until both surfaces are clean, you can use your finger nail to scrape harder residue if you wish but nothing else.
DON'T pour the alcohol over the CPU
Now apply some new thermal grease (most computer shops have it)
Be careful about how much you put on
Here are some basic instructions Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
If everything went to plan you should now be back in business
What is the best NAS for about $300 (+, - $100)? I was looking at...
(More)
What is the best NAS for about $300 (+, - $100)? I was looking at http://www.bhphotovideo.com/c/product/629822-REG/Buffalo_LS_XH2_0TL_2TB_LinkStation_Pro_LS_XHL.html,I need 2 TB of space, about 40 MegaBytesPerSecond, bittorrent, dlna , and web (configuration) access.
yahoo would not except my pasword so they asked for an alternate email address and took that as a...
(More)
yahoo would not except my pasword so they asked for an alternate email address and took that as a new yahoo messenger nickname, and then all my contacts on the old nickname were lost. I want my old nickname back so i can retreive that information, and contacts. Then i will change the pasword or whatever else is nessecary.
PC Model#Gateway mfatxnin das 300x ...I don't know what happened but now all i get is a black screen...
(More)
PC Model#Gateway mfatxnin das 300x ...I don't know what happened but now all i get is a black screen that says, ''Windows could not start because the following file is missing or corrupt.... /windows/system32/config/system''..i do not have windows set up cd cd rom so i may attemp to repair it.... what can i do?
I've got a dell dimension 5150 & I can't seem to install the Sigmatel STAC 92XX C Major HD...
(More)
I've got a dell dimension 5150 & I can't seem to install the Sigmatel STAC 92XX C Major HD audio driver - once the files have downloaded to my PC the install shield just freezes and task manager shows it as not responding (I've left it for over an hour with no change). Is there an alternative driver or does anyone have any ideas how to get round this?
