Question about Alpine CDE-9881 CD Player
Alpine 9881 cd will not play sound
I just installed my alpine 9881, in a 94 mustang with the mach 460 system
the radio works fine and sound great however when switching to a cd there is no sound
you can see its playing because there is a time cound and it will display the name of the track
any ideas?
  • Anonymous Mar 16, 2014
    HELLO
    my name is VLADA
    this radio is in my CITROEN 5,he dont make sound he play cd,play radio but dont have sound,what can be the problem,i speakers they working nice,but dont know what can be with radio......GREATHINGS from serbia and sorry for bad english :)
  • 146 Answers
If you had to connect the remote amp turn on lead from the headunit to the factory amp turn on lead you may find your problem there.
On many headunits there are 2 blue remote wires 1 for antenna and one for amp turn on. The antenna remote only supplies power when the radio is playing not when playing CD's. If you hooked the antenna wire to the amp trigger then the amps shut down when you play a cd. If that's not it let me know and I will research further.
Posted on Jan 04, 2008
CD will not play. The CDs goes in and out fine and looks like it is playing according to the display. I can change songs, fast forward and reverse through the songs according to the display but nothing...
Do you have the radio hooked up to an amplifier? If so, it sounds like you are using the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) to turn the amp on. The antenna remote wire turns off when leaving tuner mode.
Jun 22, 2011 | Alpine CDA-7863 CD Player
What connection do i need to connect my cell phone (droid x) to my car stereo alpine CDE-9881
There is no physical connection to connect any cell phone to that receiver other than an Iphone. The only option you have is to buy an fm modulator that has a 3.5mm headphone plug and plug it in to your phone. Then start playing your media.
Mar 01, 2011 | Alpine CDE-9881 CD Player
I HAVE A 2002 GT MUSTANG CONV. WITH 32,000 MILE ON IT. THE FACTORY CD MACH SOUND SYSTEM IS MAKING A STICKING NOISE WITH THE CD. JUST STARTED TODAY WHEN TRYING TO SWITCH CDS. RADIO WORKS FINE. ANY...
Dust is your enemy here, as well as cigarette smoke. Try a cheap CD head/eye cleaner. the one you want has a fabric coated face, and is available at Costco, Walmart or Radio Shack. You will need to use it several times before you see results.
Mar 09, 2010 | 2002 Ford Mustang
Alpine cda 9884 has no sound in cd or ipod mode
actually, chrysler/dodge has factory Infinity sound systems installed. The nice part about these systems is that you dont have to bypass the amplifiers in order to put a new radio in, but simply power up the amp by hooking up the amp turn on wire at the harness. The alpine should have 2 blue wires coming off of the back, one that is solid, the other with a white stripe. The one that is solid only has 12v when the fm/am radio is on (used for power antenna) but cuts off when other sources are used (cd,aux,ipod). My guesses are, you have the amp wire on the vehicle harness (blue) tied into this wire, instead of the BLUE/WHITE wire on the alpine which has 12v as long as the radio is on. i hope this solves your problem, 9 times out of 10 on a chrysler this is it.
Auto Tech
DA2 (Supa)
Jun 07, 2009 | Alpine CDA-9884 Car CD/ MP3 Player
2000 Ford Mustang AM/FM/CD car stereo bass not working
check your amplifier mustang with 460 mach stereo have aplifiers in the trunk behind or it may be a fuse
Mar 21, 2009 | 2000 Ford Mustang
Cannot operate Alpine CDE 9881
Hello!
Hopefully this will help you out.  The manual for the 9881 can be gotten here:  http://vault.alpine-usa.com/products/documents/OM_CDE-9881.PDF
Copy the entire line into your browser, and you will have it.  Don't forget to save it to your system.  It is in PDF format, so if you don't have a reader, pick up one for free here: http://www.adobe.com/
Good luck with the "new" car and radio!
Ken
Jan 08, 2009 | Alpine CDE-9881 CD Player
No sound with USB and IPOD Apline IDA-X100
You connected your blue alpine wire (power antenna) to your blue wire (amplifier remote on) on the BMW harness adapter. You need to undo this, amputate your blue alpine wire (because your E36 has no power antenna) and connect the alpine blue wire with white stripe (remote power) to your blue wire on the harness adapter.
When you switch source from the radio, alpine is shutting off your amplifier through the connected power antenna wire. Since you're not listening to the radio anymore, it sees no reason why it should give it power.
Dec 27, 2008 | Alpine CDA-9851 CD Player
Alpine 9885 - no sound with cd's or ipod
have you fixed it yet? if not try this. your car probably has factory amplified speakers. hook up the remote wire AND the power antenna wire to the blue factory amp wire and it should work just fine
Mar 08, 2008 | Alpine CDA-9885 CD Player
Radio sound but NO cd or ipod sound
Radio is screwed.
But try these these steps:
Clean the eye of the head for reading CD. Must open up the radio.
IPod: check for good connections from Ipod to PCB.
Feb 23, 2008 | Alpine CDA-9856 CD Player
Alpine CDE 9881
You must have a faceplate from that exact model, no others will work. You can try to contact Alpine for a replacement. If it is any consolation, someone has a useless faceplate, because it won't work with anything else, either. Try running an ad in your local lost & found column, you just might get lucky, especially if you offer a reward.
Jul 28, 2007 | Alpine CDE-9881 CD Player
Alpine CDE-9881 CD Player Logo
277 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
