Yes, this model uses two convergence chips--either STK-392-110 OR
STK-392-150--both are the same part but the 150 chip lasts longer.
Some history for you:
The
two chips are black in color and 2 1/2 inches wide and 1 1/2 inches
tall with 18 pins each. They are as you look from the back of the set
on the far right side--usually on a large metal
heat sink
with fins and some versions have them on two smaller
heat sinks
side by side----they will have the full STK number printed on them in white.
When
they are installed a white grease to transfer heat quickly is applied
to the metal back of each chip----after some years the grease dries out
and one of the chips fails.
Both chips and any of the 12 or so
protect resistors around them need to be CHECKED and or replaced and the set adjusted with the
Hitachi
remote--pretty easy repair.
If you can do this repair you can buy the parts on
Ebay for less than 14 dollars plus shipping--
If you cannot do the repair--shop around your area as most
shops
charge 300 or more for this kind of repair--make sure whoever you get
to do it BOTH chips are replaced or you will have the same trouble
again in a few months--some clowns will just change one chip........
If they say "It has to go to the shop" keep looking as any good tech can do this repair right in
your home in about 1 hour---I know as I have done hundreds of these repairs for people here.
If you have questions or need directions or advice let me know----
I am here to help people--if this
information helps you rate this solution--I do this here for free.
SD TECH
